Old 07-10-2016, 04:11 PM   #21 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by ST2008 View Post
OK, but why some state that we should keep vacuum as higher as much possible in order to have higher mpg.
For myself, the vacuum shows in Torque pro are 21psi for idling and 8 to 12psi for driving in a freeway (60mph). And I have no clue how to control the vacuum.
I also use torque pro. It seems to incorrectly use psi instead of inches of mercury when displayi g vacuum. The 21 psi you see is actually 21 inches of vacuum.
The Following User Says Thank You to ksa8907 For This Useful Post:
ST2008 (07-11-2016)
Old 07-10-2016, 04:24 PM   #22 (permalink)
That BMW engine still suffers from isobaric losses like every engine with a throttle.
t vago (07-11-2016)
Old 07-10-2016, 04:53 PM   #23 (permalink)
Ok thanks. it's good to know.
Old 07-11-2016, 08:41 AM   #24 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
21 PSI would be some monster boost!
