Old 12-08-2011, 09:56 PM   #1 (permalink)
What Tire pump do you use?
I want to see what people are using to get their tire pressures to a higher psi efficiently. The gas station by our house struggles to get tires to 40 psi in any reasonable time. I know people get upwards of 80-100 psi, so what are you using? I don't want to take 20 minutes filling up my tires locally, I'm willing to by a decent compressor/pump.
Thanks
Note:icon doesn't make sense, but I liked it
Old 12-08-2011, 10:05 PM   #2 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Sears has a Craftsman oil less compressor that works well for me at home( I added a 10 gallon air tank for using air tools at home). I am a Freightliner tech, so I use shop air at work. I also have a jump-pack that has an inverter and compressor that I take with me on the road. All work well for the 60psi that I run in my tires. Some truck stops have an air hose like they have at convenience stores that will pump a LOT faster than their smaller brothers.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 12-08-2011, 10:58 PM   #3 (permalink)
Which compressor at sears did you purchase?
Old 12-08-2011, 11:03 PM   #4 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
6HP Coleman air compressor with an 80 gallon tank in my garage. Works great for running all my air tools, too. Only takes up about 2.5'X2.5' floor space. Requires a 30 amp 240 volt circuit. IIRC, it cost around $700 at Sam's Club. Money well spent.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 12-09-2011, 12:00 AM   #5 (permalink)
Grasshopper - '11 Ford Fiesta SES
Team Ford
90 day: 50.37 mpg (US)
Feejer - '09 Yamaha FJR1300 AE
Motorcycle
90 day: 42.73 mpg (US)
I use a little Bostich pancake compressor that came packaged with a trim nailer brad nailer and a stapler. I run sidewall max at 51 psi and don't know if it will go much higher very fast.
Kirk
Old 12-09-2011, 06:27 AM   #6 (permalink)
Diesel
I bought the stand alone compressor, no tank attached. I already had the 10 gallon tank and the pressure regulator from a junk pancake compressor. Sears sells the same compressor already attached to different tanks. I've had mine for 6-7 years.
Boat tail project
Old 12-09-2011, 07:34 AM   #7 (permalink)
The same cheap red oil less pancake compressor I bought in 1998 to build the first of two houses. I think it came with a brad nailer as well that I still have. Tools have a tendency to hang around me a long time when they are not in a shop where people can wander around and pick them up. My brother still has his SENCO nail gun he bought in 1980, that sucker is heavy. Many of my tools I bought in 1969 were still at my shop in 1999 SK Wayne made in the USA.
regards
Mech
Old 12-10-2011, 02:29 AM   #8 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
I just use the Slime tire pump/compressor that I keep in my trunk. It doesn't too long to pump up to ~50 psi. Then again, I have low-profile tires on large rims, so I might not be pushing too much air.
Old 12-10-2011, 08:45 AM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Most of the time I just use the gas station as their compressor is set at around 90 PSI and fills tires plenty fast, I haven't found a single gas station that has failed to give me a quick tire fill up, running at 50psi.
