Old 07-11-2015, 06:14 PM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
2001 ALH (VW 1.9TDi) Tuning using VAGECDSuite?
My £2000 ($300) Octavia comes equipped with the ability to upload revisions to the map in the ECU of the car.
This is the first car I have owned that has had such a function.
Freeware software is available online that allows you to alter the values that map the following criteria:
Driver's Wish (this controls the max fueling at given throttle pedal input %)
Boost Target (Maps the requested boost level from the turbo for a given RPM/Fuel volume)
Smoke Limiter (Controls volume of fuel based on air volume and RPM)
Torque Limiter (Sets fuel volume limits based on RPM)
In essence then, I have the ability to raise /lower fueling levels and boost levels on a fairly granular basis.
The output is available via the "View performance" function:
I'm wondering whether it would be possible to alter the fueling and boost settings to maximise economy?
Initial thoughts would be around improving the torque in the lower revrange and a leaning off of fueling at cruise RPM (circa 2000-2500rpm).
I'd appreciate your thoughts on what (if anything) could be achieved!
Thanks
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
The Following User Says Thank You to 320touring For This Useful Post:
me and my metro (01-16-2021)
Old 08-28-2015, 10:06 AM   #2 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
is there a way to lower consumption at cruise speed and increase fuel under load?(IE, cruising at 60, rpm 2200, ascending an overpass/hill, increase rpm)
how are you getting this to the ECU? vag-com cable?
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 12-18-2020, 09:12 AM   #3 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
this vag edc suite works great for edc15+ version cars ecus 1999-2005 diesel cars at least.
You can and you should:
- Optimize egr at the moment I have fully turned it off
- Optimize pedal response the drivers wish make it slower for eco driving
- Optimize boost for each RPM levels (correct AFR for best efficiency)
- Optimize your IQ advance for each RPM levels and each IQ levels
- You can make more power without affecting the engine efficiency
- You can make constant IQ program for testing different aero or mechanical changes.
- Make custom launch control and different kind of rev limiters
- Mechanically tune best engine CAM timing aka torsion value for best efficiency
I have done in my cars propably closer to 5000km pure ECU program road testing trying to find most efficient setups for my diesels. If you have a car that have this ecu and own a flashing cable I am able to offer you a custom program.
My current AFR setup is 14.6% better than stock. I got it 4,2% better by optimizing quicly better boost levels for each RPM points. Propably still little room to improve there, but quite nice boost with little effort.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Old 12-31-2020, 04:24 PM   #4 (permalink)
16 Ferret Circus
bnmorgan's Avatar
GrumblyDavidson - '00 Harley Davidson Road King FLHRP-I
90 day: 38.37 mpg (US)
Golf - '04 Volkswagen Golf GL-TDI
90 day: 38.29 mpg (US)
So, what would it take to go from just a scangage to doing the above to an 04 golf with BEW? and exactly how big an elephant am i asking to eat?
the e30 is dead
Old 01-06-2021, 09:54 AM   #5 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
First learning to use that vag edc suite about one week. Basics you learn in one day.
Then learn how and which direction to change values 1-5 weeks depending what you want to do.
Tests those different setups on road 1-5 weeks
Thats about what I have spent time plus you search all the time new ways to improve your setup.
Old 01-16-2021, 09:26 AM   #6 (permalink)
90 day: 40.51 mpg (US)
Any control of injection timing?
Old 06-29-2021, 06:38 AM   #7 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Full control to whatever IQ timing you want and find to work best.
