Old 06-02-2009, 12:37 PM   #1 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
what tires should i run?
my xB needs tires...it takes a non popular 185/60-15
i was looking new goodyear fuel max tires at 80bucks a pop
or i was looking at Falken ZE-912 tires at 58bucks a pop
would the fuel max tires be worth it?? i drive 80miles a day...yet i do like to take some corners...i dunno, grrr
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 06-02-2009, 01:42 PM   #2 (permalink)
Hi,
As far as I'm concerned, better tires are never a waste of money. Having said that, what are the ratings on these two tires?
Old 06-02-2009, 01:48 PM   #3 (permalink)
This is a fuel economy forum, use the fuelmax tires!
Plus, you have a different car for fun cornering.
Old 06-02-2009, 03:17 PM   #4 (permalink)
cheap yet balla
buster - '97 JEEP Grand Cherokee LTD
Send a message via AIM to energy0uth
sup GREG!
I say cheaper = better for the amount of difference you could notice.
Old 06-02-2009, 03:20 PM   #5 (permalink)
robbiewt's Avatar
Yaris? - '08 Toyota Yaris LB
90 day: 41.87 mpg (US)
Send a message via AIM to robbiewt
I had Falken ZE-512 tires on my old Elantra. They had pretty good grip in the wet and snow. Plus I frequently got 38 MPG out of it--even though the EPA highway was only 30 MPG. I don't know how similar the ZE-912 is.
Old 06-02-2009, 05:55 PM   #6 (permalink)
Also had Falken ZE-512s on my Legacy. They gripped well for 10k miles and then the grip went to hell. Don't know how that applies to the -912s or how you drive, as I routinely left-foot braked to hang the rear end out to counter understeer in corners and pulled J-turns in the work parking lot (at least for a little while), but the point about lack of grip when worn may apply. Other tires I've had usually retained a much greater percentage of their original traction when they were worn equally as far.
Old 06-02-2009, 06:19 PM   #7 (permalink)
MPG...what?
point taken
i guess i'll order the fuel max's next week
-10 Yaris sedan
-96 Tercel
Old 06-02-2009, 11:06 PM   #8 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Other tires that I am considering:
for dollar value: Falken Sincera SN-828
only $60 including shipping for a silica compound tire
Michelin Hydroedge, straight from Michelin that it's their best LRR tire for small cars, Harmony is next
Nokian H, straight from Nokian that it's their best LRR tire for passenger cars
Old 06-10-2009, 08:54 AM   #9 (permalink)
MPG...what?
I just mounted the FuelMaxs on last night, yay, seem ok so far...i can still light 'em thru 3rd gear tho...right now they are at 35psi, after a few hundred miles i'll crank them up to 55psi
-10 Yaris sedan
-96 Tercel
Old 06-10-2009, 09:23 AM   #10 (permalink)
Why waste any time? Go 55 right off the bat.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 02:17 PM
How many PSI do you run in YOUR tires? 1337 EcoModding Central 130 08-07-2014 09:35 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 03:05 PM
Crapped. 2 tires have bubbles. XyKo EcoModding Central 37 09-04-2008 05:55 PM
