Old 01-09-2010, 12:11 PM   #1 (permalink)
Black Beauty - '13 Hyundai Elantra
First mods for 96 Prizm
Alright, so some of you may remember my thread asking what car to get. I ended up with an automatic 96 prizm. I'm pretty satisfied considering I only had about a one week time frame. Automatic sucks, but I got it from an old guy who moved like molasses, so I doubt it was driven too hard.
Anyway, I got 29-30 on the first 3 tanks, bitter cold and lots of snow.
Working on the nut behind the wheel
Just got the tires pumped up
Thinking about instrumentation (see other thread)
Would like to do wheel covers cause mine are rusty and look bad anyway. Best way to do this?
Want to put in a grill block. The car heats up really fast and engine temp gets really close to the middle line even in the bitter cold, so I don't know how much I can block and have it safe for summer. My grill looks like this
Would you recommend blocking the top, bottom or both? Which would make the most difference?
Other suggestions always welcome. Thanks!
Old 01-11-2010, 08:28 PM   #2 (permalink)
Should I take the lack of responses to mean that I'm doing everything exactly right and don't need any help...
Or more that I should keep it to one question at a time?
Old 01-11-2010, 08:32 PM   #3 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
well... since it stays so warm... is your fan fuse working?
by your mpg.. looks like you got an epic score for winter time.
get a vacuum gauge. it's easy to install and remove.
single person car thread
The Following User Says Thank You to luvit For This Useful Post:
justjohn (01-11-2010)
Old 01-11-2010, 09:27 PM   #4 (permalink)
Ok, how do I check if my fan fuse is working?
Old 01-11-2010, 09:36 PM   #5 (permalink)
epic stock master
luvit's Avatar
when i bought my old used car, i checked all the fuses, and investigated any empty fuse slots.
one fuse i found missing was the fan fuse. it was under the hood with a bunch of other fuses.
i saw a fan relay too, but once i replaced the fuse all seems fine.
you'll hear a fan kick on when your temp gauge reads about 2/3rds
btw, i also found a bad relay for blinkers on the backside of my driver-dash fuse box... who put relays on the back where i could figure out how to release it?
Old 01-11-2010, 09:48 PM   #6 (permalink)
Well there might be some miscommunication. My temp gauge is only hitting 49% right now.
I spose I should dig around just for kicks anyway though.
Old 01-11-2010, 10:00 PM   #7 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
I'd block the top grille
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
The Following User Says Thank You to Domman56 For This Useful Post:
Old 01-11-2010, 11:15 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
justjohn -
I agree with Domman56. You can block the top grille, and maybe even the top half of the lower grille. If you use carboard for testing, you can just rip it out if it gets too hot.
I may be wrong, but form the pictures, it *looks* like you can stuff pipe-insulation tubing into the front of the lower grill. Some people do that because :
- It's cheap
- It's dark, so at a glance you don't "see" the mod in slots that are supposed to be dark
- It's easy to yank out if you are running hot
You may have vertical slats in the lower grille, so it may not be as straight-forward as I am describing. I am thinking you can cut a length of tube and stuff it in horizontally ... googling ... Ok, you do have vertical slats that are pretty close to the opening of the grille, so tubing may not work as well as I thought :
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
justjohn (01-12-2010)
Old 01-12-2010, 02:11 AM   #9 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
ive also seen people stuff those long pool floaters in there as well
but yeah, block the top, watch the temp, then repeat with the bottom
Past Present Future?
The Following User Says Thank You to alohaspirit For This Useful Post:
justjohn (01-13-2010)
Old 01-12-2010, 07:15 AM   #10 (permalink)
Do you have a scangauge?
Jetta TDI Duct Tape Mods Sayyad Aerodynamics 31 09-22-2011 09:46 PM
My turbo-delsol- aero mods pgfpro Aerodynamics 67 11-09-2010 10:14 PM
could we estimate the gains expected from mods modmonster EcoModding Central 9 01-15-2010 08:32 PM
Cd change for irreversible mods Piwoslaw Aerodynamics 3 11-14-2009 04:50 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
