Old 07-23-2019, 02:41 AM   #1 (permalink)
Was the 2017 Hyundai Accent the last car with 14" rims?
Originally Posted by California98Civic View Post
I think the bolt pattern on the Miata is the same as the 4th-7th Gen Honda Civics... 4x100. If that's true, the rims I currently have, 15" MINI 7-hole alloys fit your car. 12 lbs each.
Hopefully the hub is the same or larger. I think Toyota uses the same bolt pattern but their hubs are smaller than anyone else's.
True. Civic center bore is 56.1mm and these MINI wheels bolt right up. Seems the Miata has 54.1 center bore... needs hub centric rings to adapt the 56.1mm wheel)to the 54.1mm hub. Can be had cheap online (10 or 20 bucks for the set).
A while ago I saw a Corolla (that identified as a Prizm) with HX rims. I posted the picture on Imgur so I could share it in that thread and of course people on Imgur were cancerous.
I tried to see if any manufacturers still made any 14" rims and found this: Will the Hyundai Accent Be the Last New Car to Offer 14-Inch Wheels?
From what I can tell, from 2012 to 2016 they had the same wheels, in 2017 they had different 14" ones, and now the 2,100-pound car has at least 15" wheels.
I have seen many LXes and EXes for sale with HX wheels. They are a great choice at just 11.75 pounds each. This list only shows six lighter OEM wheels, with Mazda wheels as low as 9 pounds, but Porsche wheels are just 7 pounds! Wheel weight chart most listed MUST SEE!!
Then there is a list of aftermarket wheels and just the As were at least as long as the OEM wheels. I think that eight were lighter than the HX rims, which weigh 11.75 pounds, but wheels keep getting bigger and bigger.
That list has 20" rims and one set just from the As weigh 38 pounds each, more than triple the weight of my rims!
What are your favorite stock rims and why?
Old 07-23-2019, 11:51 AM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The Mitsubishi Mirage--which wasn't around when that article was written--still has 14" wheels standard.
ETA: The 2019 Accent weighs 2502 lbs in its lightest trim.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Xist (07-23-2019)
