What's in your trunk?
When reading hyperyaris' thread about rear seat removal, I thought that there should be a thread in which everyone could brag about the junk in their trunk. Admitting it is the first step, etc. ;)
So here's what's in mine:
By getting rid of everything I don't really absolutely need may save an extra 5-10kg, but I think that what I have is a good minimum. |
Small tool kit, umbrella, dirt. The spare is under the false floor.
Jack, spare tire, bottle of oil, and 2 sleeping bags in the trunk.
Back seat has a bag of tools, including 3/8" socket set, couple of screw drivers and smaller pliers, vise grips, channel locks, a 1 foot section of pipe for a mini breaker bar, and a bunch of various nuts and bolts. And, a Tercel Haynes manual. |
...nada! I'm already aware that WEIGHT = FE loss, to the tune of about 1-2% per every 100 pounds (from EPA data).
...for those interested in *where* the EPA got this number, here's the basic equation: (w1/w2)^0.72 = (mpg2/mpg1) |
My trunk is clean but I plan to save 10 kg, I'm on a diet... :)
Golf clubs and golf shoes are the only thing I keep in my trunk that is not associated with the vehicle...(spare tire and jack are in false trunk with some small car cleaning supplies). The clubs weigh about 15 pounds...I am heavily addicted to golf and I'm ready to play at a moments notice...a weight allowance I am willing/have to make!
Whats in mine? Nada!
http://ecomodder.com/forum/member-vt...7-23072009.jpg Apart from the spare wheel and jack.... ollie |
I don't have a trunk - it's a hatchback. But what gets carried back there is (usually) one Border Collie (a bit over 50 lbs), her blanket, and a couple of empty grocery bags for when I need to stop at the store. The under-floor compartment has the usual spare tire, jack, &c, and tire chains in winter.
I go back and forth between keeping the spare tire & tools in the back, and having it empty. Currently they're in there. But the rear seat has been out of the car for quite a while now - over a year.
I'll tell you what WAS in my trunk as of 1 hour ago...
about 350 STINKIN POUNDS OF TOOLS!!!!!!!!! talk about sluggish, man! It took a lot longer to get to 50 than normal. and the back end was definitely lower and very rolly. but now that i have removed all of the chrome and steel, its a LOT better. ill give you the rough list.
1 steel trolley jack 1 set of wrenches from 5/32 to i think 1 7/8 1 set of wrenches from 5mm to 34mm 1 24 inch crescent wrench and multiple smaller ones (total of about 6) 2 1/2 inch torque wrenches 1 set of lug sockets files gear pullers several sets of regular sockets ratchets, tiedowns, etc 10 or 15 screwdrivers 1 tub of wheel bearing/brake grease 1 24 inch 1/2 drive breaker bar and of course the SPARE Well, you get the picture. HEAVY and i didn't realize i left it all in there 4 days ago! go figure. |
