Old 09-28-2009, 11:03 PM   #11 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 40.6 mpg (US)
I've had homemade wheel covers on for a couple months, and haven't noticed any adverse braking effects. The only thing I've noticed is a ton of brake dust on the inside of the wheel cover when I take it off.
Actually, about 2 weeks ago, the lug nuts came loose on one of my wheels...the tire is also losing a lot of air, so I'm not really sure what the cause of the problem was on that one. It was probably due to the lugs not being tightened enough the last time I tightened them, and they eventually loosened, causing the tire to wobble around too much and lose air.
Alternative to wheel spats and smooth wheel covers? ESmooth Aerodynamics 17 12-10-2013 08:26 AM
Wheel Covers using bicycler DIY ... cfg83 Aerodynamics 33 07-21-2009 12:42 AM
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
