Old 05-03-2022, 02:55 AM   #11 (permalink)
A lower unsprung mass is often pointed out as an improvement for handling, so even if the aluminium wheels could have a negligible effect on fuel-efficiency it might be worth taking a look.
Old 05-04-2022, 05:30 PM   #12 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.09 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 30.79 mpg (US)
-Typical Honda 14" steel wheels weigh about 18lbs / 8.2kg
-Honda Insight 14" wheels (aluminum alloy) weigh 11lbs / 5.0kg
-Honda Civic Hybrid 14" (aluminum alloy) weigh 16lbs / 7.3kg
- Honda Civic Hybrid 15" (aluminum alloy) weigh 7.0kg
The Following User Says Thank You to alexshock For This Useful Post:
Ecky (05-04-2022)
Old 05-04-2022, 05:57 PM   #13 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Not bad! The material being farther away from the center of rotation has a multiplicative effect on the moment of inertia, but if the overall diameter of the wheel is larger (and spinning more slowly) that partly negates it.
Old 05-04-2022, 06:48 PM   #14 (permalink)
IIRC aluminum and car tire are about equal, while steel is heavier. So for a given rolling diameter, there'd be no penalty with aluminum.
Say for instance, an i3 155-19 vs a Beetle's 165-15.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Ecky (05-04-2022)
Old 05-04-2022, 08:36 PM   #15 (permalink)
a Beetle's 165-15.
IIRC the last Beetles resorted to 155R15 when they were still available in Mexico, yet in Brazil the Itamar series resorted to 165R15 only because the suppliers had already discontinued the 155R15 locally. Seems like Tornel had also discontinued this size, which now is only available through specialist tire suppliers such as Coker Tire, or from Pirelli at an extra cost as part of a range of tires which caters specifically to ancient/collectible cars.
freebeard (05-05-2022)
