Welcome!
First "mods," though not necessarily aerodynamic
First thing's first, let's get rid of these stupid virtue-signalling emblems, as well as all the other extraneous badges. I really hate all the badges car companies put on their vehicles. https://i.imgur.com/7JiUtDC.jpg
Much better! https://i.imgur.com/FxVWk4U.jpg Also cleaned off the back end. Of emblems! Not of dirt. The rainy weather and freeway driving has not been kind. :( I did, uh, LEAF the name of the car, however. https://i.imgur.com/8izwS1g.jpg Next, I added a critical piece of safety information. https://i.imgur.com/GQzgGXo.jpg Finally, I utilized the EVSE bag as a roadside emergency kit. I won't be taking my cord with me as they cost $200, and I don't need some crackhead to smash my window and take it. Inside the kit are (VERY) basic first aid supplies, an extra jacket, warm work gloves, an old leatherman, a 9-in-1 screwdriver, a safety vest, ponchos, toilet paper (very important) pen and paper, and a flashlight. I also have a blanket, and underneath the bag where they're pinned in place, 30-minute flares. Not pictured: a reflective triangle thing. That's pinned between the Bose box and the cargo liner where it won't come flying out and decapitate me in a crash. https://i.imgur.com/UriHebl.jpg |
First real Aeromod
I removed the front mud guards, and put them facing the opposite direction on the leading edge of the rear wheels. This creates a sort of wheel spat. I saw someone else do this on a Nissan Leaf forum and thought it might be kind of fun. EDIT: Here is a link to the thread in question.
They certainly weren't going to stay where they were, they were an aerodynamic eyesore facing the other direction. Doing this deleted the old wheel "spat," if you can call it that. I've left a picture of that one. Laughably small. BEFORE: Facing rear of vehicle from front. This is the left rear tire. https://i.imgur.com/HL6xvkK.jpg AFTER: Same as before. https://i.imgur.com/TJVrLj9.jpg I secured it to the metal wheel well in the back using the two screws that came with the mud guards, as well as a different self-tapping screw underneath, which drilled into the lower rocker panel. They are very secure. If you look closely, you can see approximately 80 holes where I drilled until I found the "sweet spot" for mounting. The other side looks much cleaner and more professional. https://i.imgur.com/DiEC6Lf.jpg The best part is, should I choose to sell the vehicle, the mod is easily reversible, and will leave no extra holes. Here's a side view down the right side of the car, from the front, showing where the flap was deleted on the front tire, and where it is located now on the rear. https://i.imgur.com/z8BYb9d.jpg It's a start. Side note, previous owner left a dent in the rocker panel which I'm now acutely aware of...... |
Quick mockup of future plans.
Decided to bust out the jigsaw while the car was up on jackstands and the rear wheel was off, just rough-cut a half-circle of the diameter of the rear wheel arch, wanted to mock it up. EDIT: There was a jackstand in front of the jack. I took the pressure off the jack but left it in place as a sort of paranoid second layer of safety while working.https://i.imgur.com/LBKNwW0.jpg
Without the rear wheel in place, it looks pretty great. My long term plans would be to fabricate something with fiberglass that would be "reversible" or symmetrical. A sort of compromise, making something that sticks out as little as possible from the sides of the car to clear the tires, and can be molded TWICE, and installed once on each side of the car. I have never made anything with fiberglass before, but it doesn't look especially difficult, just expensive and very time consuming. I might also go the "metal support and ABS or coroplast" route, but I really want something that looks neater than corrugated plastic. Here you can see it sitting over the top of the side with the tire still installed. https://i.imgur.com/435P5rB.jpg The rear of this is not aerodynamically pretty, but it's also not accounting for whatever taper I could squeeze in the limited space. Overall, I am satisfied with at least seeing what could be. Already planning more ideas for future mockups. Addendum: I left the rear mud guards on as a possible mounting point for a flexible skirt to hang down below the planned fiberglass part. I want to close off as much of that wheel well as I possibly can. In the future, I may remove the trailing mud guards if that proves infeasible. |
Next goal in sight---Front Wheel Spat!
Looking underneath the Leaf, it's relatively smooth. Not nearly as aerodynamically "dirty" as my Yaris was, for certain. The rear bumper actually goes up smoothly into a rear diffuser instead of a big open parachute like the Yaris.
Up front are some flexible rubber wheel spats in front of the front tires. I think I can do better. I would just add material to drop them down closer to the ground and split the air more effectively, leaving these stock pieces in place. It must be said that their placement (IE the angle and shape) is interesting, and makes me wonder if this was something designed in a wind tunnel--and therefore something to keep and just improve rather than deleting and remaking. https://i.imgur.com/f7CiDWt.jpg I also plan on purchasing either rain gutters or some other such material to make side skirts. No sense splitting the air if you don't give it somewhere to reattach. |
A crackhead is likely to be interested in an EVSE, but as an aside, I've purchased Leaf ones for as little as $20. I've modified one of them to run on 240v, and I've got the parts to modify another.
Right now I'm just using the included EVSE to charge every night. I rent, and though the homeowner is OK with it, I'd have to pay an electrician to make room in the breaker panel, install a new circuit, and install a receptacle. I'm comfortable doing all of this work myself, but sadly I don't own this place, so I'm not going to take on that liability, and paying an electrician is looking like well over a G. So for now it's just LV-1, and I can use LV-2 when I go to the library or other places. Where did you find them for so cheap? Hopefully not purchasing from crackheads who stole them... Lol |
You can buy an evse for around $140 and hide them easy.
