04-16-2015, 02:37 PM
#11 (permalink)
Doubt my lights are on an average of 5% of the time, just say 10% so numbers are easier, $13.82 vs. $3 vs. $1.40/month would be closer.
CFL save $10 a month and could recover bulb cost in 2-3 months.
LED vs CFL save $1.60 a month, a years saving covers one LED bulb.
04-21-2015, 01:38 PM
#12 (permalink)
home of the odd vehicles
I bought a dozen 14 watt CFLs at goodwill last week for $0.10 each!
04-21-2015, 04:25 PM
#13 (permalink)
Dang, that's a sweet deal.
The Following User Says Thank You to KFM For This Useful Post:
04-21-2015, 06:16 PM
#14 (permalink)
You can buy single or multipack CFLs at Dollar Tree all day long for the wonderfull price of exactly $1 (seasonal availability applies)
I won't say they are the most efficient or the best quality but hard to beat.
The Following User Says Thank You to rmay635703 For This Useful Post:
04-21-2015, 07:27 PM
#15 (permalink)
Lots of Questions
THD has dozens of 9.5W (60W replacement) LEDs on sale right now for under $5. Still not as good as the typical CFL price, but way better than the typical LED price. If anybody was interested, I could pick some up and ship them out.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
04-22-2015, 12:17 AM
#16 (permalink)
You have to look at the amortized million lumen hour cost and not the unit cost. Incandescent bulbs are cheap to buy but run to $7.50 per MLH. CFC'S run $2 to 4 per MLH. LED can run as high as $5 per MLH. Not hard to see the bargains here. You just need to know how to calculate the MLH cost.
04-22-2015, 12:29 AM
#17 (permalink)
OTOH, LEDs give a much better quality light (for my tastes, anyway). Much closer to natural daylight.
04-22-2015, 01:15 AM
#18 (permalink)
No idea what OTOH means? Color temperature is what you are talking about. I like 3,000 K to 3,500 K output. True daylight would be well over 5,000 K which is too blue shifted for me. The lower temployee is considered warm and the higher temps are considered cool.
04-22-2015, 02:28 AM
#19 (permalink)
OTOH means On The Other Hand, IIRC...
It is not just the color 'warmth' (the K grade) but also the spectral components of the light that matter.
By design LED light is hard blue (at least, the most efficient type is) so it needs a coating of fluorescent material to produce other colors.
Likewise, a CFL tube needs a fluorescent inner coating to produce a mix of colors that shows white.
Which of these produces the most natural mix depends on the quality and design of the fluorescent coating used, more than the type.
The Following 3 Users Say Thank You to RedDevil For This Useful Post:
04-22-2015, 04:45 AM
#20 (permalink)
Are LEDs expensive? Considering Philips is about to launch an 8.5w bulb that's as cheap as some of the 4w Chinese bulbs I've bought over the years... I don't think they'll be "expensive" for much longer...
LEDs are a bunch of diodes, a circuit board and electronics. That's always going to cost more to assemble than a single wire sitting inside a vacuumed-out glass ball.
I love LEDs. Have had color issues with the cheap ones, so I'm currently switching to white. I tend to buy bulbs that are coated... so technically less output per watt, but they aren't eye-searing to look at... and are still more efficient than CFLs.
Since I started installing them three years ago, I've only had one go out... and that one was in an outdoor socket exposed to potential water contamination from rain.
