View Poll Results: Why do you drive an auto?
I drive a manual 84 54.90%
I have driven both, and prefer auto 19 12.42%
I have only driven automatics 3 1.96%
I couldn't get the car I wanted with a manual because of buying used 27 17.65%
I couldn't get the car I wanted with a manual because they aren't made (excl hybrid) 16 10.46%
I couldn't get the car I wanted with a manual because it's a hybrid 4 2.61%
Voters: 153. You may not vote on this poll
Old 12-15-2010, 09:55 PM   #91 (permalink)
Prototype builder
jason1973tl's Avatar
Big Vic - '03 Ford Crown VIctoria LX
90 day: 21.92 mpg (US)
Originally Posted by tumnasgt View Post
DSG transmissions are clutchless autos, and before them there were also automated manuals, which were just manuals operated by a computer (though they weren't very smooth). Honda also has a CVT with a clutch, which would fine as well.
As far as I know, there's nothing stopping car companies from having the torque converter lockup at low speeds, other than a slight added cost in having a stronger lockup clutch. In fact, I hope there is a good reason they don't do this, as otherwise they have been wasting huge amounts of gas for the sake of a little bit of extra profit.
It might be interesting to note that early Chrysler products here in the states before most companies started adding an overdrive to their autos advertised lockup torque converters to save gas. If they aren't using them now I would like to know why. It is possible to buy lockup torque converters for performance applications here as well.
Old 12-15-2010, 10:13 PM   #92 (permalink)
tumnasgt's Avatar
The Charger - '15 BMW i3
Pretty well all cars now have lock up torque converters, it's just that they only lock up in the top gear or two, and only above certain speeds with minimal throttle.
So they don't even have to add parts, only improve the quality of the lockup mechanism so it can handle the added stress of acceleration.
Old 12-15-2010, 11:42 PM   #93 (permalink)
JacobAziza's Avatar
Big Orange Work Truck - '83 Ford F-250
90 day: 27.54 mpg (US)
Jessica's - '04 Toyota Matrix
90 day: 41.21 mpg (US)
Ninjette - '01 Kawasaki Ninja EX250R
An automatic without a torque converter would never work, or they would have one now. The only way I see to make that work is to have a computer use a clutch and change gears and such. It would be a massively complicated system. I am not an auto tech, but I don't see how you could practically make an auto work without a torque converter.
As far as the U.S. is concerned. We are a lazy bunch. I don't know about Europe and the rest of the world, but Americans want to talk/text on their cell phones, play with sat nav,mp3 and various doodads in their cars and generally want driving to be as easy as possible so they can be distracted with other things.
A sequential gearbox (like formula one cars have) could easily be computer controlled, making a torque converter-less automatic. On the other end of the complexity/cost spectrum, you could have a centrifugal clutch, like a go-kart.
I guess neither is very practical.
I agree about the laziness. We need a remote so we don't have to walk 2 feet to change the channel, and we keep bluetooth in our ear at all times so we don't have to reach all the way into our pockets and then hold up a heavy cell phone to our ears.
Soon our cars will drive themselves, and only Luddite purists will still drive their own cars.
Bringing new meaning to the term "automatic"
Originally Posted by Piwoslaw View Post
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
Old 12-16-2010, 07:20 AM   #94 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If that's the case, how did GM manage to sell 90% automatics in Western Europe in '98?
I'd think that number doesn't include their local European branches (Opel / Vauxhal), but just their American branded cars - which would be mainly automatics.
Old 12-16-2010, 09:55 AM   #95 (permalink)
The Torque converter in my CVT equipped Altima locks up at 12 MPH. It will easily accelerate decently without ever passing 1500 RPM. It works more like a clutch than a torque converter. The special fluid used in the CVT helps to minimize slippage between the pulleys and the steel shoe segmented drive belt, which is all steel. They warranty the transmission for 120 k miles.
12 MPH is barely 3 to 4 car lengths from a dead stop.
regards
Mech
Old 12-16-2010, 10:32 AM   #96 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Curious, it does take a 3% hit on the hiway, but a couple Qs re: CVT
do you have the option to control the ratio? i.e. a ratio lever?
Can you control lockup?
Does it have a neutral?
Old 12-16-2010, 01:21 PM   #97 (permalink)
It has a manual mode with 6 different ratios.
Not a specific control of lockup, unless I haven't figured it out yet, but no button to disengage. It will disengage if you give it enough accelerator pedal percentage, but it does not do it unless you go far beyond any normal range for best mileage.
You can shift to neutral at any speed with the neutral position on the gear selector and it does unlock the converter when you shift back into drive while you are moving. At 50 MPH if you shift in neutral, then back into drive it will be at 1100 RPM until you apply some throttle, then it will lock up and the revs will rise as you accelerate. The re engagement is perfectly smooth at any reasonable speed, even Interstates at 65 MPH.
I did some low speed (30 MPH average) pulse and engine on glide and was able to get just below 60 MPG, but I would be afraid of shutting the engine off.
It has a bar graph for instant fuel mileage, an average mileage and speed reading, range till empty. these are available by a button on the dash beside the steering wheel.
The transmission fluid is specially designed to provide grip for the CVT's steel belt and the pressure and friction of the cogs on the pulley faces actually changes the viscosity of the fluid to promote traction.
Top gear is about 2200 RPM at 72 MPH, about 3k at 100, but I have never been that fast.
1500 at 50 MPH.
The cruise control does not change the engine RPM around here where the grades are small, just adds or reduces throttle to compensate for the grade changes.
regards
Mech
Old 12-17-2010, 01:51 AM   #98 (permalink)
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
I drive a stick. Driven many a slush before but there's just no "fun" without the 3rd pedal!!!
And I really don't want to know how much it would cost to replace a clutch (or two) in a DSG.....
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
Old 12-27-2010, 11:45 PM   #99 (permalink)
Personally, I think that everyone should drive a manual unless they have a physical condition preventing them from doing so, as having to pay some attention to your car makes it harder to text, eat, sleep, drink, talk, and play monopoly with your kids while you drive.
I agree 100%.
First car was manual, and most of the cars I've owned have been manual.
Old 12-28-2010, 12:47 AM   #100 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Arguably, everyone should drive automatics, so they can concentrate on what they should be doing - driving - instead of worrying about which gear to shift to, how lightly to lift the clutch pedal, whether to place their right foot on the brake or gas pedal, etc.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Ecomodders can Drive the Prius PHEV and more. Green Drive Expo Madison July 17 &18 ericbecky Events & Meet-ups 11 07-14-2010 10:02 AM
Locking an automatic in a single gear? bennelson EcoModding Central 11 11-14-2008 01:03 PM
Hybridizing a 2-wheel drive pickup bennelson EcoModding Central 5 10-14-2008 11:53 AM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
