Old 10-02-2015, 12:34 PM   #11 (permalink)
Dark Egg - '12 VW Touraeg
That makes sense because that rim appeared to be GM equipment.
And that is pretty bad because that means it not a cheap Chinese wheel made out of recycled beer cans.
Except the extra set of 20" factory Dodge wheels I have that I didn't use have "made in China" proudly cast into them. I would bet if the GM ones don't say "made in China" it's only because they actually were but told them not to print it on the wheel itself.
In defense of the low profile tires, my Aspen handles much better with the 20's compared to the 17's but it's only really noticeable if I was autocrossing the thing. Then again I was the only guy with a pickup at the autocross events I entered LOL!
Old 10-02-2015, 01:37 PM   #12 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
If I was running a 20-24" rim, you can bet that I would have it wrapped in a 35-40" tire. No rubber bands here, no sir.
(37x13.50 on 22x14s)
Yes sir!
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 10-02-2015, 10:44 PM   #13 (permalink)
That's not low profile, that's just gigantic.
Old 10-02-2015, 10:56 PM   #14 (permalink)
I would not put it past GM to lie through omission on something like that.
Yes, putting taller wheels helps up to a point.
The over all #1 thing you can do to a 3rd generation Camaro like mine or firebird or T/A to increase the lateral skid pad G forces the car will hold is to put 17 inch wheels on it. But you still continue to run a 26 to 27 inch over all diameter tire (not exactly rubber bands).
You can go larger than 17 but it become hit or miss with that platform for some reason.
Old 10-02-2015, 11:10 PM   #15 (permalink)
Originally Posted by wdb
I still don't understand the allure of gigantic rims + rubber band tires. I think they look stupid.
It affects 'turn in', the time it takes for the vehicle to respond to steering wheel input.
Old 10-02-2015, 11:29 PM   #16 (permalink)
apc
Mazda - '11 Mazda Mazda2 Touring
90 day: 38.93 mpg (US)
Originally Posted by wdb View Post
This is something that has never made sense to me. Smaller diameter rim means more tire is required to obtain the same overall diameter. More tire means more tire material - rubber, belts, whatnot. And yet they charge less for them. Boggles the mind.
Supply vs demand prolly. Maybe just a more common size rim so a larger market.
Old 10-02-2015, 11:50 PM   #17 (permalink)
Caused by a stone on the road inside a construction zone. Could happen to any one who drives through road work.
I can show you a similar thing (large crack in the side bead) with a regular profile tire, from hitting a rock that rolled down the mountainside.
Old 10-03-2015, 08:28 AM   #18 (permalink)
Super low profile tires are the stupidest thing ever. Is there a handling benefit? maybe a very small one, at the expense of a harsher ride. I just can't see going any lower than a 50. And people that go lower than that on a truck should be beaten. It looks like ****.
Old 10-03-2015, 11:23 AM   #19 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Maybe. There are a lot of variables in play there, even just in the wheel/tire realm.
Old 10-03-2015, 12:21 PM   #20 (permalink)
It's merely the only thing I could think of in favor.
The best turn-in I've had was on 145/15s on 5.5" rims. But they couldn't keep up with the brakes (downhill in the mountains), so I went to 165-50/15.
