Old 11-21-2020, 12:47 PM   #11 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by M_a_t_t View Post
What video/car? It sounds like a mod I was thinking about trying.
Found it ! : https://youtu.be/PcQGu5N8tTc
At the 4:21 mark
EDIT : I'm also adding this interesting link here, so as not to clutter this thread up :
https://gmauthority.com/blog/2019/04...-aerodynamics/
Old 11-21-2020, 02:55 PM   #12 (permalink)
https://youtu.be/PcQGu5N8tTc?t=262
I'd call those fences rather than strakes. The GM Authority example is curved and at an angle to nominal air flow.
What the headline giveth, the last paragraph taketh away. -- Scott Ott
Cd (11-21-2020)
Old 11-21-2020, 03:47 PM   #13 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Yes. FENCES would be the correct word.
Here are two examples I mentioned earlier, as seen on jets .
The jets being an Su-22, and an F-14 .
I was amazed the first time I did a tuft test on my 93 Civic. The car has prominently raised rain gutters alongside the windshield.
I thought for sure these would act as fences, and direct airflow upwards to the roof, but the air just skips right over them, and apparently without tripping into turbulence.
Oh and yes, I too was puzzled at the curved strakes.
And quite a steep curve as well.
I would have thought for sure such a thing would have just tripped up the airflow.
ID:	29594   Click image for larger version
The Following User Says Thank You to Cd For This Useful Post:
freebeard (11-21-2020)
Old 11-22-2020, 10:50 AM   #14 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Just out of curiosity, I added this side shield to see if i could direct airflow away from the mirror, as it spills around the windshield.
I even planned to take video, but everything flopped.
From the test, there was massive turbulence behind the mirror.
I also noticed the tufts just behind the mirror pointed straight up right as I began driving. This was evident at perhaps less than 10 mph.
In the photo, you can see how the piece has bowed outward. I installed it straight.
So what do you all think is happening ? Is air actually spilling over this shield and creating a massive vortex ?
I did some CFD that seemed to verify that even with a huge side shield, the air just spills right over the sides as if it's not even there.
Would it be worth it to do further testing on this ?
ID:	29604   Click image for larger version
ID:	29605   Click image for larger version
Old 11-22-2020, 11:47 AM   #15 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I would assume that it is blocking that flow around the windshield creating a sort of wake effect. Maybe the pointed up tuft is because the side airflow is now looking for a different path, maybe towards the (I assume) low-er pressure on the roof/ top of windshield area?
Is it worth testing? Entirely up to you. If its creating a wake then maybe not in its current version.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 11-22-2020, 11:51 AM   #16 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Were you thinking a scaled up version of this? This is the newest honda fit btw
1995 Mercury Tracer
Old 11-22-2020, 12:13 PM   #17 (permalink)
I'm pretty sure that would suck problematically when driving in snow. I wonder about the Fit.
Old 11-22-2020, 01:01 PM   #18 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
You think snow would collect there?
1995 Mercury Tracer
Old 11-22-2020, 01:56 PM   #19 (permalink)
My 1958 VW Beetle convertible collected snow on it's flat windshield, a problem I don't remember in a Beetle sedan. Something about the square upper corners.
Old 11-22-2020, 03:28 PM   #20 (permalink)
All my bugs collected snow on the windshield, I think it's a function of defrost strength
freebeard (11-22-2020)
