Exhaust is hot, but is it hot enough? I'm not smart enough to have that kind of math in my head, but if you want decent power out of a Stirling, it's all about the delta-T. Lower temperatures require larger heat exchangers, larger displacer pistons, and generally lower revs. You might wind up going backward in terms of efficiency.
It might be easier to just stick a hundred Seebeck devices onto the exhaust pipe and obviate your alternator.
