03-22-2011, 08:22 AM
#11 (permalink)
This is not really a hybrid when only the electric motors power the wheels. It's the same principle behind diesel-electric train engines. Keep the combustion engine at a constant load where it works optimally in order to generate electrical power.
It's kinda like what the Volt was supposed to be.
03-22-2011, 10:52 AM
#12 (permalink)
This *is* a series / serial hybrid; not a parallel hybrid. It really is a hybrid; just a different kind of hybrid than we are used to.
03-22-2011, 02:03 PM
#13 (permalink)
No, it's just the opposite of a diesel-electric train, where the electric motor/generator is only acting as a transmission. (If trains are hybrids, then so is every car with an automatic transmission a hydraulic hybrid :-)) The Porsche design had both batteries and an IC engine.
03-23-2011, 10:02 AM
#14 (permalink)
If there are batteries or capacitors involved, then it is a series / serial hybrid. In fact, it is the electricity that is the "transmission" between the genset and the electric drive motor, so that is a hybrid, too.
Two types of motors are involved in moving the vehicle = hybrid.
03-23-2011, 10:25 AM
#15 (permalink)
needs more cowbell
How many times does it have to be explained to you? Two types of energy storage NOT involved (i.e. batteries and diesel) = NOT hybrid.
Are you saying the torque converter makes automatic cars a hybrid? you would make the term completely meaningless. It is about storing/reusing braking energy, regardless of the conversion processes.
Hybrid train - Wikipedia, the free encyclopedia
"uses an onboard rechargeable energy storage system "
Does it make sense now?
03-23-2011, 11:36 AM
#16 (permalink)
Can an automatic transmission provide power?
Two (or more) types of motors = hybrid.
03-23-2011, 11:55 AM
#17 (permalink)
aero guerrilla
Piwoslaw's Peugeot 307sw modding thread
The Following User Says Thank You to Piwoslaw For This Useful Post:
03-23-2011, 01:03 PM
#18 (permalink)
needs more cowbell
Can a motor provide power without electricity? Same deal. A torque converter is half hydraulic pump (generator analog) and half hydraulic motor.
Transmissions 101, a prep course...
Wrong, so stop saying it unless you embrace misinformation = irresponsible melonhead.
03-24-2011, 09:53 PM
#19 (permalink)
Motors are motors, and transmissions are not motors. The transmission is not a power source.
By your definition, a Prius is not a hybrid -- where does the electricity in the battery come from?
03-24-2011, 10:06 PM
#20 (permalink)
needs more cowbell
in part from regenerative braking, or from the wall.
If it did not recapture braking energy (or occasionally allow use of a wall socket), hybrids would get really crappy mileage with all that dead weight and complexity.
