Old 07-21-2008, 10:18 PM   #31 (permalink)
SilverStang - '00 Ford Mustang
90 day: 22.23 mpg (US)
Originally Posted by Tony Raine View Post
alright, since the trolls have been banned, lets continue..........
if you have the mechanical skills to do it yourself, a stick shift swap may be beneficial. but only if you can sell the automatic to recoup the loss (as far as i know, an automatic cost more than a standard).
back to tire swapping, my switch from 29" tires to 31" tires is the equivalent of swapping from my 3.73 gears to 3.49 while keeping stock tires. i've run this tire size for around 2 years and have had no transmission problems (related to tire size).
i think rear tire swapping would be a good way to "test" to see if your car can handle "taller gearing" before making the jump to actual taller gears. (since tires are a wear item and are replaced, but gears usually aren't.
The tranny swap is looking to be my best bet. I can probably sell off the automatic somewhere because it is in excellent condition with only 66,000miles on it so it should still be worth about a grand or two considering a new automatic trans costs about $5k.
Finally got my 20% above EPA
Old 07-21-2008, 10:27 PM   #32 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
never heard it referred to that way, but yeah, thats about right.
is the 2000 still on the fox platform, though? i thought they strayed away from it around '95.
Ford Fox platform - Wikipedia, the free encyclopedia
The '04 Mustang was the last derivative of the Fox platform, though it was somewhat modified after '94. You can, as far as I know, still swap much of the drivetrain of an '04 Mustang into, say, a '78 Fairmont with relatively little drama.
I remember hearing that leading up to the release of the current ('05+) Mustang that it was the first complete redesign in over 25 years, so that makes sense.
Old 07-21-2008, 10:40 PM   #33 (permalink)
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
The Sn95 94-98 has a narrower rear end by 3" but otherwise is similar to the 99-04 rear end. This refers to the 8.8".
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 07-22-2008, 08:31 PM   #34 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
Haha, even though it still might be considered a fox platform, they aren't that easy to swap parts like that from year to year. 79-93. 94-95. 96-98. 99-04. Are where you get the different designs, each with their little tweaks that make swaps to different styles, not impossible, but sometimes difficult and not cost effective. I've built a few mustangs in my day (All Foxes), and I've been involved with a transplant of an 03 4.6 Cobra powerplant into a 89 mustang and believe me, there was drama! When swapping parts and trying to stay cost effective in a mustang, its better to stick with your style mustang for most parts, or at least make sure to cross reference first. They did change the axle length also from 93 (foxbody) to the 94 (sn-95) year and I'm not sure if it stayed the same after that or not.. other than the 79-93 model years, my knowledge of mustangs drops off quite a bit.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
2008 World Fuel Economy Championships - Scores Dan. General Efficiency Discussion 24 06-23-2008 09:50 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
