Old 03-30-2012, 06:13 PM   #51 (permalink)
Panzerwagon - '02 Skoda Fabia
90 day: 53.88 mpg (US)
While I doubt the engine swap is still on the cards, I thought I'd make you aware of this
Marvin
So here’s the deal. It’s never been done before (aside from apocryphal tales), but I just happen to have a Mazda MX-3 V6 shell floating about and a Mazda 2.3 V6 Miller Cycle engine (code-named KJ-ZEM, for those who enjoy such things) sitting about doing nothing. And I’m damned sure neither will move without the other.
The final aim being 40 MPG, 122 mph, 217 hp and 210 lb.ft drive-track-home car.
Old 04-02-2012, 06:34 PM   #52 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Looks like a super complicated project you have going there !
Will you have to cut/bash in the inner fenders for clearance ?
Old 04-03-2012, 12:51 AM   #53 (permalink)
Marvin
The guy who's doing that is a co-moderator (actually, he's my admin) on another site. Fascinating project.
Old 04-03-2012, 03:42 AM   #54 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
A bit of V6-porn: SAE 920677
Old 04-03-2012, 04:34 AM   #55 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Here is a crazy question : can a Honda engine be installed into a Mazda ?
Specifically the Civic VX engine ( and transmission )
Old 04-03-2012, 06:09 AM   #56 (permalink)
Smart guy, almost like he's from another planet. A very hungry, indigo planet.
The Following User Says Thank You to RunningStrong For This Useful Post:
niky (04-04-2012)
Old 04-04-2012, 04:23 AM   #57 (permalink)
And an unfortunate fascination with green platypii... yes... Forgot for a moment who was posting that link!
On the Mazda247 boards (you'll have to search), someone was doing something similar. Installing a fuel-injected D15B into a Protege.
The big issue is... the mounts issues, electronics issues and assorted headaches with fitting an engine that turns the wrong way round into a regular engine bay means you'll be spending a lot of money for waaaay too little benefit.
Better to get a JDM or European Mazda engine with low-displacement and high power to swap into that Mazda or eco-mod the stock motor.
There are some tricks that can be done with Mazda mills. If you've got a Miata, there are the Euro-spec cams (drops it down to 90 hp), which should do well combined with an aftermarket air-fuel controller.
Mid-90's Mazdas have a wide choice of 1.5 and 1.3 liter engines that will fit, as well as the European diesel.
The last-generation BJ Protege had a huge variety of engines, from 1.3 gasoline (sweet, economical little thing) to the 2.0 turbodiesel (which is where they got the intercooler for the Mazdaspeed Protege from... and which has fascinating gear ratios...)... all as far away as a phone call to a motor importer. Performance swappers usually go for Probe/MX-6 2.5 liter V6s, but across the pond, it's not uncommon to see the smaller 2.0 V6, as well. The Supercharged Miller, on the other hand, is a truly RARE conversion.
If you want to work with the stock motor, for the 2.0 FS-DE Protege or Protege5, the 1.8 liter FP-DE cams may just fit in the motor... and they have a lower profile... it should be easy to find a 1.8 owner willing to swap up for more power... better yet, use the FP-DE motor from the get-go, as that's sweeter revving. There are guides on cam-profiles between regions at Protegé FAQ
Then there's the 626 transmission trick for the same car... which gives you a longer 5th gear. Some owners with autos have switched wholesale to 626 manuals, which give both a longer fifth and a longer last gear. Also, for some reason, the gear synchros aren't as crunchy on that transmission, but that may just be me...
And since the Protege FS-DE is tuned so conservatively and has such good knock resistance, you can lean it out pretty far with an AFC in an attempt to find better economy.
There's a lot you can do within the stuff available for the car without looking at exotic cross-manufacturer swaps which will involve more wiring and custom fabrication than its worth for a measly small jump in MPG. You can even fit a rotary into an MX3... but I'm not sure you'd want to do that if economy is the goal...
Old 11-19-2012, 10:15 PM   #58 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I still love the look of these cars, yet keep finding things that change my opinion of the car .
The latest being the safety rating.
A first generation Insight is actually rated safer in a crash, despite having an aluminum body that is nearly 500 lbs. lighter than the MX-3.
I just always assumed that the Insight would crush like a soda can in an accident, and that the steel mx-3 would hold up better.
So horrible fuel economy, horrible Cd ( given its teardrop shape ) , very heavy , slow as mollases - even with the V-6 , not very safe, prone to rusting, not very reliable, and as pointed out in the previous posts the car has a massive blind spot.
Is there anything good about the MX-3 besides the look ?
Old 11-19-2012, 10:30 PM   #59 (permalink)
Uh? Nice steering?
Old 11-19-2012, 10:40 PM   #60 (permalink)
Cd
Ultimate Fail
Cd's Avatar
They don't handle very well either.
Good for cooking rice though :
