Old 03-05-2020, 07:00 PM   #141 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
May you be touched by his noodly appendage. R'amen
Transmission type Efficiency
Old 03-06-2020, 12:51 AM   #142 (permalink)
90 day: 35.79 mpg (US)
You guys are weird.
I cleaned the oil control orifice and replace the o-ring, bolted the rocker arm assembly back on, tightened the bolts which were loose when I started, did another valve lash, reinstalled the valve cover, distributor, spark plugs, and installed the new spark plug wires.
She started up and ran--I didn't make her worse!
She still made noise, but I went back and watched the video. She is definitely quieter!
Shouty has said to track down noises with a long screwdriver. It seemed like the alternator, which is "new," but I will try degreasing everything.
I do not know when I replaced that alternator, but it looks new, so I probably did not install it too long before taking her off of the road.
Old 03-06-2020, 09:48 AM   #143 (permalink)
One supposes it would be possible to record the engine running and post it such that people that know can assist troubleshooting your random noises.
Old 03-06-2020, 10:01 AM   #144 (permalink)
This was the engine before I tightened down the rocker arm assembly:
I sprayed it down with degreaser, hosed it down, and will see how she sounds once she dries.
Old 03-06-2020, 10:08 AM   #145 (permalink)
Thanks.
Kinda almost sounds like exhaust manifold leaks
Old 03-06-2020, 03:05 PM   #146 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
You guys are weird.
In our defense you are the one that brought up the Flying Spaghetti Monster AKA: FSM
I need to start trying to refer to the FSM when there is a chance that it will have the information that I need.
The Following User Says Thank You to JSH For This Useful Post:
Fat Charlie (03-06-2020)
