01-03-2014, 11:45 PM
#11 (permalink)
Regular extension cords get quite unwieldy when cold. I'm told that the blue cords are meant for cold and stay more flexible?
01-04-2014, 12:20 AM
#12 (permalink)
Smeghead
Some cords (color does not really matter) are rated for colder weather. cords that are not rated are a hazard as the insulation cracks when handling. Also if you are in a cold climate the cords included on most block, oil pan, water heaters gets brittle and a piece of cold weather rated rated cord should be spliced in to where you handle it.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
01-05-2014, 12:50 PM
#13 (permalink)
Too many cars
I hate to see salt on a Firefly/Metro/Swift!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
01-05-2014, 01:02 PM
#14 (permalink)
Me too, me too...
If it's any consolation, this is probably only the 5th or 6th winter the car has seen (of 17), and none were in its first 7 years.
And I always get underneath with a pressure washer as soon as the temps climb above freezing... and all the nooks and crannies have been rust treated multiple times. It should last...
01-05-2014, 02:06 PM
#15 (permalink)
Too many cars
Have you treated the insides of the front control arm mounts? I've been meaning to fill mine with oil and then drain it out.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
01-05-2014, 05:10 PM
#16 (permalink)
Yup. There's an 'access hole' part way up the forward vertical portion, and I've sprayed in there several times (and will do it more).
01-06-2014, 01:35 PM
#17 (permalink)
Master Ecomadman
My avg is down to 43 mpg in the is -15F degree weather.
- Tony
01-06-2014, 01:44 PM
#18 (permalink)
Using the car to break up ice on the (long-ish) driveway at my garage today is not helping the overall picture: 24.5 MPG (US) for a round trip where I'd normally see ~60.
01-06-2014, 06:45 PM
#19 (permalink)
TheEgg - '18 Volkswagen Tiguan SEL Premium 90 day: 29.55 mpg (US)
Winterized diesel and long engine warm up times have dropped my average by close to 10 mpg. I've discovered that when it's below zero, my engine will never reach optimum temperature at all unless I turn the heater off.
01-06-2014, 07:47 PM
#20 (permalink)
y do you let your engine warm up? i hear its good to start driving after a few secconds the car gets warmer faster when working, your tranny temp will remain cold untill you start driving so technically if you let your car warm up the parts stay colder longer then anticipated. is it different betweeen gas and diesel?
