02-11-2020, 12:06 AM
#181 (permalink)
As of posting this went up 40 minutes ago:
I need to do this with my Dasher. ...now that I know about having a step in the contour.
Face the danger and row away from it.
David B. Frohnmayer _________________
02-11-2020, 12:52 AM
#182 (permalink)
I really enjoy your videos. Thank you very much.
02-11-2020, 01:03 AM
#183 (permalink)
Yes, I don't think the downwards projection needs to be as great as I show with the BMW, but my measurements (and the literature) shows this can create good downforce (and all else equal, that means less drag). At least some downwards curve... and I'd make it a gentle contour.
The Following 4 Users Say Thank You to JulianEdgar For This Useful Post:
02-11-2020, 01:25 AM
#184 (permalink)
Thank you!
02-14-2020, 07:22 PM
#185 (permalink)
The cheapest Aero mod is pumping up your tires to 44psi Price: Free.. upto 7% free MPG (suggest lowering in bad weather conditions)
02-14-2020, 08:09 PM
#186 (permalink)
Sorry, how is that an aero mod?
The Following 3 Users Say Thank You to JulianEdgar For This Useful Post:
02-15-2020, 02:20 AM
#187 (permalink)
Tires with higher pressure are narrower, reducing CDA?
02-15-2020, 05:50 AM
#188 (permalink)
Too many cars
But they might be taller!!!
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
02-27-2020, 01:17 AM
#189 (permalink)
Undercar airflow, pressures and lift - understanding how air dams, rough undersides and belly-pans influence lift.
(And decreasing lift normally decreases drag)
https://youtu.be/xMCIzR4K0JA
04-03-2020, 02:40 AM
#190 (permalink)
Why I don't think AirTabs works in many situations people are attempting to use them in.
https://youtu.be/AdlScWEDqCM
