Writer seeking examples of tested DIY aero mods for book
Julian Edgar, former editor of Autospeed (which many here probably visited regularly), is writing a book about road vehicle aerodynamics.
Julian said he may also want to get in touch with individual modders via e-mail. |
http://ecomodder.com/imgs/montana-pa...boattail-1.jpg
http://ecomodder.com/forum/showthrea...-6-a-6069.html Not all tests show measurable gains, and may underline the difficulty of testing very small changes: http://ecomodder.com/imgs/corolla-tu...vg-driveby.jpg http://ecomodder.com/forum/showthrea...olla-2390.html See also: Tested: Airtabs on a mini van, A-B-A - no measurable effect |
http://metrompg.com/posts/photos/aer...ail-rear-z.jpg
http://ecomodder.com/forum/showthrea...esults-94.html http://metrompg.com/posts/photos/mir...ded-detail.jpg Reflections on side mirrors: testing drag vs. MPG http://metrompg.com/posts/photos/ACFBE7D.jpg http://metrompg.com/posts/photos/ACFBE85.jpg Testing grille blocking & wheel skirts: +5.7% improvement |
scattershot
This one's maybe less useful because it's an "all-in-one" test that incorporates a number of non-aero mods, though the majority of the gains are likely from drag-reduction.
http://ecomodder.com/forum/attachmen...1&d=1412084540 http://ecomodder.com/forum/showthrea...7-a-30111.html |
Is a wind tunnel good enough?
Thanks for the replies so far. As MetroMPG said, I am writing a book on home car aero modification. The book is quite large, and so I can use plenty of examples. It is being published by a UK publisher, but it will be distributed worldwide. At this stage it is looking like being 100,000 words and 350 pics.
As with any print publication, good quality pics are needed (ie typically at full res out of the camera, not at web resolution). If you want to appear in the book, I'd suggest that you do the following: 1. Email me a couple of high res photos and a short description of what you've done, and how you tested the results. julianedgar1 at gmail.com 2. I'll get back to you to let you know if I am interested. (I hope I will be, but I might already have examples that cover the same ground, etc.) 3. I'll then ask you to write a more detailed description, or provide more pics, eg a step by step, or testing of different versions, etc 4. You will be mentioned by name in the book, as will EcoModder If you have any questions, I am happy to answer them. |
I really appreciate the work you did at AutoSpeed over the years.
Why didn't you use EcoModder.com - View Profile: Julian Edgar instead of creating a new account? I don't have any documented result, but I did observe at Darko wind tunnel last September when aerohead and gumby79 tested their pickup trucks, and aerohead's 1/3rd scale model. http://ecomodder.com/forum/showthrea...-32673-31.html |
It's an exciting book to write.
Jaguar's chief aerodynamicist has been very helpful with providing me with material. F1 aerodynamicist Willem Toet has been commenting on some paras, and my technical editor/consultant RH Barnard is just about to get the first chapter to give me feedback on. These are the chapter headings: Introduction Chapter 1 – Theory Chapter 2 – Aerodynamic vehicles Chapter 3 – Flow visualisation Chapter 4 – Pressure measurement Chapter 5 – Noise measurement Chapter 6 – Measuring drag and lift Chapter 7 – Reducing drag Chapter 8 – Reducing lift and increasing stability Chapter 9 – Improving flow through heat exchangers Chapter 10 – Engine intakes Chapter 11 – Reducing aerodynamic noise As far as I know, it will be the only major aero book aimed at normal people modifying road cars. |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
