Old 05-25-2009, 10:37 AM   #11 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by stevey_frac View Post
I think i might stop into a transmission shop, and see what they think. If they quote me hundreds of dollars that'll be a no go for now at least.
I'm afraid if it's not something you can do yourself, it's definitely going to cost in the hundreds of dollars for labour. The transaxle itself will be in the hundreds (if you can't just get the differential gears).
On a side note: I've been spending too much time on the site. I've yet to do any big mods, but i'm thinking of doing a front air dam, wheel skirts, moonies, i've already decided to switch to synthetic fluids, and i'm seriously looking at an ignition kill switch, because i've been EOC coasting down hills for the past two days.
LOOK WHAT YOU'VE DONE TO ME! :P
Another one bites the dust!
Old 05-25-2009, 01:38 PM   #12 (permalink)
Jalilah - '07 Chevrolet Cobalt LT
90 day: 40.57 mpg (US)
I've sent an email to a transmission shop asking them about the work. We'll see how/if they reply, and what they have to say.
I just read a report saying that they expect oil to hit $200 / barrel by 2014. I think we are truly about to hit the last days of gasoline cars...
Any savings i can squeak out look more important when you consider oil that expensive!
Old 05-25-2009, 02:01 PM   #13 (permalink)
Stevey. . .the only way oil hits prices like that is in the event of another speculator runaway freight train.
I've worked with some guys in the oil industry and there won't be any shortage of oil for production sake any time soon.
Shell just dropped new reports into alot of offices paying their geologists to go back and run scans on old wells because a substantial number of wells have refilled partially. When you consider that and about 1/4 of the wells that are already located and accounted for in barrells are not tapped I doubt oil runs out or production or supply even slows in the least over the next 20 years.
Speculators are the single cause behind gas prices. Go talk to an oil company and they will tell you its not their fault and they aren't making the profit that causes the price inflation.
Old 05-25-2009, 02:07 PM   #14 (permalink)
If you look at oil prices over the past three years, we are currently on track to repeat the previous spike to $140 / barrel by the end of the summer. Regardless of the cause... it's still happening.
Old 05-25-2009, 02:12 PM   #15 (permalink)
Yes and no. . .Its completely off topic but im happy to continue over private discussion of if someone else wants to start a thread. If anyone else wants to know why I don't believe that will happen just msg me, I don't want to hijack yet another thread. . .The bounty on my head is already too high lol.
Old 05-25-2009, 03:13 PM   #16 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Back on topic.
Gearing changes allow you to fully realize the fruits of aero and weight improvements.
Aero & weight reduce the engine torque required at a given road speed. Changing gearing reduces the air flow through the engine (in itself a major cause of engine friction) and in a gas engine that means a lower fuel burn, all this at the same road speed. If you don't regear the vehicle yopu have to use a more closed throttle to acheive lower air flow and a throttle plate is nothing but an entropy generator.
You would think regaring would be more effective on a gasser than a diesel but the high compression of the diesel is another good reason to minimize air flow. Unfortunately, gearing is expensive. These arehigh-precision bits of machinery that require complex manufacturing tecniques which means high cost. Still, if you really think oil is going to $200/bbl, your choice may boil down to coughing up the cash for gearing or just not going.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 05-25-2009, 03:38 PM   #17 (permalink)
Originally Posted by Big Dave View Post
Back on topic.
This engine is a monster in it's class. A 2.2L beasty with good old fashioned torque. The average size engine in this class is 1.8L (a full 20% smaller), and I believe there is a 1.6L contender. Despite this, the cobalt gets very good highway fuel economy. Part of that is lower gearing, but they didn't go far enough from the factory for my tastes. Even without considering any other modifications, there is NO reason for this big engine to be turning over at 2500 RPM and sitting at 20% engine load on the highway. This thing is desperately asking for longer legs. My calcs predict that it would be much more comfortable sitting at 2200 RPM, which is still higher then an XFE final gear swap would put me. This would up engine load to around 30%
If oil does hit $200 / bbl, I fully expect that i'll be pushing my car to work on all the inclines, then coasting down the declines.
Either that, or i'll have the first cobalt with a full boat tail.
-Steve
Old 05-25-2009, 04:32 PM   #18 (permalink)
The best possible thing you could do is to rip out the gear you want larger and find a custom one. . .thats expensive and laborious. Trans swap with a relatively new trans will always be expensive. Swapping out a civic trans from 92-96 is cheap because they are plentiful. Your XFE trans not so much. In your case if you are doing it yourself it honestly might be cheaper to pop the trans apart and find something really enormous to fit in there.
New trans on a new car will run about a grand or more. New gear could be as little as 50 bucks. . .but instead of a 1-2 day thing its a saturday sunday all day, monday night, tuesday night and wednesday night to get it back in the car.
If you're not doing the labor this is not worth it at all.
Even if gas costs 8 a gallon it takes forever to recoupe the 2K its going to cost in gas. . .
If you aren't doing it yourself and if its over 500 bucks you are far better off just ripping extra weight out of the car. . .Spare seats, insulation AC lines, veins compressor, manufacturing your own fiberglass shell(including the hours spent learning and screwing up several copies). . . You might get 10 mpg extra on a huge gain of mpg, which I doubt. It would take forever to pay that down even with an extra 10 mpg. . .
If you think its going to get that bad take all the trunk lining stuff out, the spare tire, the metal frame for the trunk and put in strong mesh netting and coat the underside in a big gortex bag, take the carpet out, dash, door panels, speakers, fans, glove box.
Doing all of that would get close to giving you the same mpg increase and its less than 100 bucks for water proof fabric and mesh netting for strength. . .
Lighter wheels and tires when you have to switch and losing as much weight as you possibly can are also cheaper than paying a mechanic to do this, trust me I work in a shop lol.
Standard trans swap for '96-'00 Civic? brucepick EcoModding Central 6 12-17-2010 10:16 PM
MetroMPG.com mailbag: VW Polo transmission swap not very successful MetroMPG EcoModding Central 6 07-04-2009 12:39 AM
GM XFE trucks: Progress? Frank Lee General Efficiency Discussion 15 11-24-2008 12:15 AM
News: Cobalt XFE sales 2x more popular than estimated, more XFE models coming MetroMPG General Efficiency Discussion 27 07-30-2008 08:42 PM
have some questions about a vx or hx swap soj8888 EcoModding Central 3 07-24-2008 11:54 PM
