Old 02-28-2009, 07:00 AM   #21 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I installed an XFi cam from Delta cam and an 8 degree advanced timing gear on THIS THREAD and we had no issues at all.
GeoMetroforum.com - got mpg?
Old 02-28-2009, 08:58 AM   #22 (permalink)
xfi cam and 8 degree sprocket
I had read that before and forgotten the particulars, part of becomming ancient I guess. Thank You for the reminder!
Old 02-28-2009, 07:59 PM   #23 (permalink)
Hi-Tech Redneck
suprf1y (Mike) mentioned that his cams (he has economy and performance grinds) are made to work with his gears. I know this because it has been proven over and over in the Metro/Swift community. The Delta Cam regrind is supposed to be a stock "Metro XFi" spec'd camshaft, so if you have a stock Metro XFi and want to install an advanced timing gear from 3Tech, you can and will get similar results from the mod regardless of what cam you are running.
I do however recommend using 3Tech Performance parts when planning on a rebuild or upgrade.
Wow Howard Dean is killing it on Leno tonight. OfficeLinebacker The Lounge 5 06-07-2008 11:28 PM
