Old 11-09-2012, 08:07 AM   #1 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Zemco flowsensor question
Hi,
I have a question regarding the mounting of the flowsensor. The installation manual says it should be mounted vertically with the flow going up.
I don’t have much place under the hood and if I mount it that way, the hoses and the pear pump make some steep angles. They have to go from a horizontal position to a vertical position in a short length. It also makes appear some cracks at the ends of the pear (made of rubber) if they are slightly folded (might lead to air getting in the line). So the most in-line it is, the better.
My question is, will it really harm reliability if I mount it horizontally ?
Does anybody have tested the 2 different positions ?
Thank you
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
Old 12-17-2012, 06:22 PM   #2 (permalink)
Hi HypermilerAX
Mounting the sensor vertical is a must for low fuel consumption cars ,I have found on large engines (v8) the orientation doesn't matter so much,how ever ,low consumption cars such as yours may have a problem with vapour bubbles.
Regards
Tp
The Following User Says Thank You to TheTestPilot For This Useful Post:
HypermilerAX (12-20-2012)
Old 12-20-2012, 11:33 AM   #3 (permalink)
AX - '95 Citröen AX
Thanks for your feedback.
Old 12-21-2012, 07:27 AM   #4 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You know, you don't have to install flow meters directly to the pump. You can use any part of fuel hose for that, so maybe you could put your flow sensors somewhere near the fuel tank? Or somewhere else where vertical position will be the best option.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
