Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 04-23-2011, 03:40 PM   #21 (permalink)
500 Mile Metro Traveler
'89 Dakota LB - blue - '89 Dodge Dakota V6 LE
90 day: 19.8 mpg (US)
'17 Fiat 124 - SunFiat - '17 Fiat 124 Spider Classica
90 day: 30.51 mpg (US)
'89 Metro - The Egg - '89 Geo Metro Base
90 day: 50.71 mpg (US)
'94 Alto - The Box - '94 Suzuki Alto Ce-L
90 day: 39.5 mpg (US)
Originally Posted by jamesqf View Post
Seems as though all this discussion has become moot, since spark plugs are slated to become outdated technology: Lasers Could Replace Spark Plugs, Making Engines More Efficient | Popular Science
yes, lasers, led illumination, solar panels, and kamm shaped bodies are all on the horizon, but the $$ of buying the new car won't offset my need for a larger gapped fine wire spark plug lol.
Old 04-23-2011, 03:42 PM   #22 (permalink)
Originally Posted by suspectnumber961 View Post
Not sure where I found this....
One solution is to voltage match the plugs, that's what I did in my car after this last round of acetone testing. I took the standard copper plugs it came with and measured voltage at 180psi @ .039" gap (about 42kV) then opened up the gap on an Iridium until it matched, I had to get a .052" gap to match the voltage between them.
I want the test equipment in your garage!!
What's your address?? ;-)
Old 04-23-2011, 04:25 PM   #23 (permalink)
...beats walking...
FWIW--Laser Ignitiators are already in-use in space-based products, both for combustion ignition (thrust motors) and explosives (detonators).
Old 04-23-2011, 07:28 PM   #24 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Hopefully it's gassers that will become outdated, and not just spark plugs.
Diesel baby!
I'm not coasting, I'm shifting slowly.
Old 04-24-2011, 02:58 AM   #25 (permalink)
IIRC, they've been "coming in the next year or two" for at least five years so far... I personally am not holding my breath.
-soD
Old 10-17-2011, 11:43 PM   #26 (permalink)
Fat wires are for insulation against heat in the engine compartment. For road use I still recommend ignition sealer around the distributor cap if it is near the front of the engine. I had 4 cyl. FWD car simply quit on the road during heavy rain.
Old 10-25-2011, 07:26 PM   #27 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Something else of note, if you are making your plugs "Hotter" on antique vehicles don't be surprized if it causes other issues.
My subaru 360 is notorious for burning holes in pistons when the plugs are too hot. I would estimate there are other antiques with this same issue.
Old 10-13-2014, 10:40 PM   #28 (permalink)
MSD 8.5's seem to work
I put these on my car along with a light weight battery and it ran smoother and probably more efficiently too.$40 Lightweight battery - YouTube
Old 10-15-2014, 10:02 AM   #29 (permalink)
The 8.5 refers to insulation thickness. The conductor resistance needs to be within a certain range as listed in the repair manual. Too little resistance in the wires allows spark noise (electromagnetic radiation) that interferes with the electronic control modules and the nearby radio or cell phone. Unless you got a great deal on the wires the extra price is not warranted since the stock wire insulation is adequate in this case. Depending on what part of the country you are in winter temperatures will affect the output of the battery. A blanket over the engine, a heat lamp underneath, and trickle charge on the battery may be needed below 15 F. For now enjoy the benefits of the tune up and reduced weight. I no longer work in a NAPA auto parts store but we did sell high performance ignition components to drag racers.
Old 10-15-2014, 07:57 PM   #30 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
Originally Posted by Joenavy85 View Post
just go find where the Blues Brothers live and take their car, it had cop suspension, a cop engine, cop radio, cop interior,.... i'm sure it had cop ignition as well, lol
Retired cop cars are fun. I've found they will get the family through hard times, but the car takes the first chance to fall apart (without causing you too much trouble) it is given.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
