12-05-2012, 09:43 PM
#121 (permalink)
Smeghead
You could file/rough up the shaft to increase the surface area of the bond.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following User Says Thank You to bestclimb For This Useful Post:
12-05-2012, 09:50 PM
#122 (permalink)
Busting Knuckles Often
+ 1
Maybe some epoxy instead? J B weld? Shouldn't take much. Thanks for posting frequent pics.
The Following User Says Thank You to WesternStarSCR For This Useful Post:
12-06-2012, 07:34 AM
#123 (permalink)
Roughing up the shaft certainly wouldn't hurt at all.
I thought about using JB weld. I thought it might be too brittle to hang onto the coroplast over time. But, if its pushed into the square of the coroplast cavity that might work perfectly. I think I'll give it a shot. Thanks.
12-06-2012, 08:36 PM
#124 (permalink)
I took both aforementioned suggestions. I cut out the silicon with an exacto knife and pulled the rods out. I took some 80 grit sandpaper to them to rough them up. Then I mixed up some JB weld and started smooshing it into the grooves. The JB weld was thinner than my expired silicon so it actually packed in there real good. I don't think I'll have any problems with it now. Thanks guys.
Here are a few pics:
The Following 2 Users Say Thank You to Daox For This Useful Post:
12-07-2012, 07:46 AM
#125 (permalink)
I can't wait to see it working. When you're planning first testing session?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
12-07-2012, 09:23 AM
#126 (permalink)
I hope to have it bench tested this weekend.
12-07-2012, 12:46 PM
#127 (permalink)
...beats walking...
What kind of "threshholds" do you think you'll use?
OPEN @ slow speeds, when ambient air is warm?
CLOSED @ high spees
OPEN when water-temp gets high (what temp)?
CLOSED @ slow speeds (to speed warm-up)
OPEN only when water-temp gets high.
I'm curious.
12-07-2012, 01:24 PM
#128 (permalink)
The programming will be almost entirely based off of engine coolant temperature (I'll also open it up when the A/C is turned on). I don't see a need to have ambient temperature or vehicle speed effect things.
I plan on having it closed all the time until engine coolant hits around 200F / 93C. This should be well above the thermostat temp (so radiator is fully saturated at 200F) and still below the coolant fan turn on temperature. This will utilize the radiator only at the maximum delta temperature which allows greater cooling efficiency so that the time the grill block is open can be minimized. I'll shut the grill block when the coolant temp falls back down to around 190F / 88C which should be just above the thermostat opening temperature. If I find that this is cycling things too much I'll adjust it so that the block closes say... 15 seconds after the coolant temp hits 190F to give some time to cool down the radiator.
The Following 3 Users Say Thank You to Daox For This Useful Post:
12-07-2012, 06:24 PM
#129 (permalink)
JB Weld
It has been said,that if you peel the duct tape back on Earth's equator,you'll find that the two hemispheres are held together with J B Weld.
12-09-2012, 09:13 PM
#130 (permalink)
Very cool! Please keep us updated!
