08-28-2012, 01:23 PM
#21 (permalink)
Formula SAE Engineer
One thing you might really want to consider is fabricating a hinge to make the door open up suicide style. The car/motorcycle will probably be low to the ground (should be due to how weight transfers side to side) so I bet it would be way easier to get out with a suicide door. Wouldn't have to twist around in what could be a tight fit in the cabin.
Max Trenkle
Student Engineer - TTU Motorsports
04-15-2014, 04:29 AM
#22 (permalink)
Hope someone still on this. I been think about the same thing using a VW dti beetle for a good mpg start and easy body mod. Just shave the 2 rear wheel well fender connect a R.QRiley xr3 rear wheel system. Minimum modification. What you think. Also will I be able to registry it as a bike? Since it was register as a car b4 , buy I live in California.
04-15-2014, 12:28 PM
#23 (permalink)
What's a "VW dti beetle"?
04-15-2014, 02:15 PM
#24 (permalink)
I mean the Volkswagen beetle TDI turbo diesel. Its a fwd with x3 rear end it be a hybrid 3 wheel drive. And the beetle rear end make simple fish tail for aero.
04-15-2014, 02:50 PM
#25 (permalink)
I had a high level of confidence that was your meaning.
A 'through-the-road' parallel hybrid is a not bad plan. It simplifies things. Fishtailing a New Beetle? I'm not so sure.
I think you'd do better to start with a Golf and pie-cut the body behind the cowl. Just a little so the door hinges can accommodate the change, or just ahead of the hinge line.
04-15-2014, 03:08 PM
#26 (permalink)
Hi Freebeard
I am very new here, yes thats the car,. You see the tail end is already tappered. Since its a 3 wheel I won't need the rear wheel fender, will the shave and replace with a panel be simpler than the pie cut?
04-15-2014, 03:29 PM
#27 (permalink)
That's kinda odd, but interesting. BTW if I were looking to convert a car into a reverse-trike, possibly would make it RWD using the transmission setup of a BMW R-series motorcycle.
04-16-2014, 01:20 PM
#28 (permalink)
Freebeard! Where can I find out more about that car?! That is awesome!
Yes, why did they keep the rear fenders? What in the world is occupying the back seat?
04-16-2014, 04:21 PM
#29 (permalink)
skippo -- My point was that the New Beetle is squarer than the old. Thinner rear fenders, wider rear valance, etc.
Xist -- I think this is the same car:
Found here with cRiPpLe_rOoStEr's Beemer power in the Grinnall Scorpion III
A simpler approach from thesamba.com:
Found via Google Images for vw reverse trike
04-16-2014, 05:51 PM
#30 (permalink)
Image search! Of course! I guess that welding your own frame and removing the center half makes sense, but the finished product does not have the seam.
I do not think there is any taper, as beautiful as that car is, I imagine that it would be obvious. I imagine that you would start the taper behind the doors, which would create a noticeable corner, unless you want to create a whole new body panel!
