Old 03-25-2016, 02:16 PM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
custom aerodynamic wheels
I bought a set of RIAL x10 5x19" for my audi a8. I did not now are they how convex from pictures but they looked nice.
When I got them I started to think how to make them more aerodynamic.
I decided to make some custom 1mm thick aluminium block plates to them. First draw the basic shape with 3d engineering program then print the shape to paper and cut out.
as you can see it took mayny samples to get the shape perfect. Then I ordered a set of those and started bending them to correct shape. They fitted nicely.
Then I decided to paint them also green and bigger triangles to glossy black. Plates are glued from behind. Time will tell will they hold Glue hold 24 kg per cm2.
Finished wheel is looking sweet and the curvature is just perfect. Although this aint yet totally ready. It still needs Tuneko centercap sticker and few other final touches.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 11 Users Say Thank You to Vekke For This Useful Post:
aerohead (03-26-2016), Andrei_ierdnA (03-25-2016), California98Civic (06-28-2016), jeff88 (04-27-2016), mcrews (03-25-2016), Natalya (06-28-2016), niky (03-26-2016), t vago (06-28-2016), UltArc (03-25-2016), vskid3 (03-25-2016), Xist (03-25-2016)
Old 03-25-2016, 02:41 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
wow.....!!!!!
no really....wow!!!!
VERY nice work!!!!!
you should use the ecomodder logo for the center caps!!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-25-2016, 03:24 PM   #3 (permalink)
Agreed, that looks very nice.
How did you go about bending them?
Old 03-26-2016, 02:36 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
I bended them just by hand over 150mm diameter pipe. The triangles also needed to twist some curvature by hand to fit the wheel outer edge.
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (03-26-2016), mcrews (04-26-2016)
Old 04-26-2016, 10:48 AM   #5 (permalink)
Veen's '09 FIT - '09 Honda FIT Sport
Wagons
90 day: 43.41 mpg (US)
Where did you order to sheet metal from?
Old 04-26-2016, 12:37 PM   #6 (permalink)
How are you dealing with the valve stem?
Old 04-28-2016, 09:26 AM   #7 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
You need to draw a 3d file, where you save the draft/drawing if to dxf format then just send the filed to watercutting company. My parts cost 30€ per set cutted. There is valve stem hole, I drilled them after the watercutting to 4 wheels.
First drive lost two of the plates so added more glue and now they hold good. The paint is not sticking so well as poles are taking hits from small rocks etc. I know I should have painted them better with primer...
Old 05-14-2016, 06:34 PM   #8 (permalink)
The Black Clio - '04 Renault Clio
These are aamzing.
Another fantastic way to add style to your car plus get better MPG. .
Im guessing you would bee a PC drawing software to do something like this, to the level of quality you have done it?
Old 05-25-2016, 04:23 AM   #9 (permalink)
Nice. did you laser cut the metal, or are they hand shaped?
Old 06-28-2016, 08:48 AM   #10 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Yes those are laser cutted:
Now also ready plates for Mini wheels 5½J x 15, ET46 5x112:
Natalya (06-28-2016), Xist (06-29-2016)
aerodynamic, covers, custom, ekotuning, wheels
