Old 10-21-2016, 05:42 PM   #1 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Diesel fired coolant heater Hydronic D5WSC Water Heater Non plug-in preheater.
I've read oilpan4 build link inspirational. The 5kw only helps when the frozen motor is running(can add a 12v pump @aproxamitly 125usd) and a has a 220v plug aka only works at home(this would cost aproxamitly $200 to install a 220v plug out in drive way) or .000005% of other places . That was fine when I lived in Washington/Portland. Now in Montana, having a failed cold start in the woods can be fatal. You are the one who inspired me to dive into setting up non plug-in pre heater as many communitys in Montana are off-grid. The 5kw block heater would require very expensive solor /battery upgrades , I live in town now but plans are in the works for moving to the country. Plan ahead...
Ordered this :
D5wsc 24v manual ,pdf.
Eberspacher Hydronic D5WSC Water Heater 24v | eBay and a 12-24v dc-dc converter $500usd.
Aready had a battery isolator (was to set up a dual battery/ alternator disable system on a previous gaser) , I will be adding a 2nd battery to preserve the starting battery, and give self jump capabilitie.
Any suggestions on additional tags?
Pros
.10gal/hr diesel 3A 24VDC 72W =5KW Hydronic heat + residual ehxsost heat under hood. Most report operating temperature reached in 15min =.025ga fule 18Wh
Will report my actual
During summer the additional battery will allow a altnator disabling switch.
At home I can just plugin a 5A 12V 60w battery float charger at night to avoid 2nd battery.
Can run multiple heating elements ( trans cooler from wrecking yard add a 12 V 5W fan for cab heat parked engine off)
Nomore waiting for heat after a snowshoeing hike.
Cons:
Price 1800usd new with instalation kit got for $500 Ebay
If I can maintain my summer milage ROI should be short.
Extra battery $100+isolator $94 ( needed any way a single battery is almost not enough with 750W stock blook heater pluged in over night @ -30 took 30min idle and 18mi to reach thermostat opening temp).
Cannot be run inside a "tightly sealed grange "
For now not a problem as I have street parking.
Original idea was an instant hot water heater running propane and a 12V pump. Theas heaters are flow activated. So a check valve/isolation solenoid would be needed to prevent heater activation from the engine.
Dreem big chisel down to reality.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
aerohead (10-22-2016), skyking (10-22-2016)
Old 10-21-2016, 09:43 PM   #2 (permalink)
I've only read the first page of the other thread.
https://www.google.com/search?q=+Eberspacher+evtv
EVTV like the ceramic heater in the Chevy Volt; I think it heats water and not air. The link points to blog posts and videos about controlling it with an Ardiuno.
OEM parts available in your nearest junkyard. I forget what they pay, maybe one-fiddy.
Old 10-21-2016, 11:36 PM   #3 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
That kind of looks like the small Diesel fired air heaters we use in our trucks to dry out our tools. They are also used to heat sleeper units on semi trucks, so they don't have to leave the big Diesel running for heat at night.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
Xist (01-29-2017)
Old 10-21-2016, 11:50 PM   #4 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
That is exactly what this is the Hydronic/ hot water version. Mt 5.9 isn't exactly a big diesel. But old technology, with no computer to help by programming a warm-up sequence.
Former
87' Hyundai Excel
Old 10-22-2016, 12:47 PM   #5 (permalink)
There should be a military version for the hmmwv, taken from surplus they should be dirt cheap but it's going to be 24v powered.
Xist (01-29-2017)
Old 10-22-2016, 12:56 PM   #6 (permalink)
90 day: 19.36 mpg (US)
Gold standard item. Hard for me to justify cost in south central US, but it's the right way to go, short of a similar and cheaper substitute.
Old 10-24-2016, 10:03 AM   #7 (permalink)
http://ecomodder.com/forum/showthrea...Coolant+heater
Xist (01-29-2017)
Old 10-24-2016, 10:19 AM   #8 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
Webasto, Bosch or Eberspacher also makes those. Popular here in the North
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
The Following User Says Thank You to Fingie For This Useful Post:
Xist (01-29-2017)
Old 10-24-2016, 11:37 AM   #9 (permalink)
Webasto is what we have at work, troublefree heat.
Xist (01-29-2017)
Old 10-25-2016, 12:23 PM   #10 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
The Eberspacher unit I ordered is a 24V . My truck is 12V so to solve this problem this was also ordered :Waterproof DC 12V to 24V 3A 72W Step-up DC-DC Converter Regulator Boost Module @Power Regulators & Converters
Where were and witch modle the HMMWV with the aux heaters were used in?
. I was stationed at Ft Riley, KS . The only cold start aid was Either and it was on 5Ton and up. No block heaters . I was responsible for 3 5-tons 2 HMMWVs all but 1 5ton would crank up @ -15 without Either ,just double glow (cycle glow plugs ,turn off, cycle glow plugs , start a trick I learned on tired 285,000+ mi Uhaul ford E/F 350 trucks they needed doble glow at +29°f) some of the insert boxes (ambulance, macanical, Como) had auxiliary heat for stand alone use with out the truck .
Former
87' Hyundai Excel
hipermiler
