12-03-2017, 04:24 PM
#101 (permalink)
Master procastinator
Originally Posted by MetroMPG
I reinstalled the top portion of the cover.
But it's only held on by two 10mm bolts, so it's easy to remove to inspect the belt and/or swap camshafts again.
Oh, ok.
I'll keep that trick with the cover in mind, might be handy sometime.
12-03-2017, 06:46 PM
#102 (permalink)
So it WAS a cas of no-compression, briefly. All the lifters filledso the valves weren't closing fully?
12-04-2017, 02:09 AM
#103 (permalink)
Yup, that's how I understood it.
Mine took a long while to bleed down. I thought I had killed it!
The Following User Says Thank You to Stubby79 For This Useful Post:
12-04-2017, 03:52 PM
#104 (permalink)
Next mod...
12-04-2017, 03:59 PM
#105 (permalink)
Looks pretty good (and familiar). How do you plan on finishing it this time? Fiberglass again?
The Following User Says Thank You to Daox For This Useful Post:
12-04-2017, 04:51 PM
#106 (permalink)
Are you improving over the previous design, or is nine years good enough for you?
12-04-2017, 06:25 PM
#108 (permalink)
Cut a row of 'speed holes' along the trailing edge to improve visibility?
12-05-2017, 01:11 PM
#109 (permalink)
Visibility is actually OK - the horizon is visible in the mirror below the trailing edge.
As for construction, I'm aiming for quick 'n' dirty: Likely coroplast and aluminum tape. I may bend & attach a length of aluminum tube for strength and to support the trailing edge.
Nothing's so permanent as a temporary fix!
Ultimately, I was thinking metal riveted on for version 2. Sag-proof... though dentable. Trade-offs!
12-05-2017, 03:56 PM
#110 (permalink)
TV antennae have a light-weight seamed aluminum tube. I have some samples.
You could make the whole thing out of that, just cut to length, smash the ends flat and drill it and pop-rivet it together. Maybe cover it with boat wrap? Like a WWI fighter fuselage?
