Old 04-11-2013, 11:28 PM   #101 (permalink)
EcoModding Wannabee
LioNiNoiL's Avatar
Thumbs up data analysis
More inflation vs. rolling resistance data for the pile.
Thank you for your diligence and care. Since data analysis (especially small-sample analysis) comprised the second half of my professional career (from which I am now retired) I entertained myself tonight by exercising some remaining brain cells with my own spreadsheet (OpenOffice Calc) analysis of these data, verified with software by Richard Lowry at Vassar:
Spearman rank correlation* (SRC) between 70psi and 60psi of feet travelled is -0.488, a weak (insignificant) decrease of feet above 60psi.
Including the 50psi data gives a SRC of +0.133, a very weak (insignificant) increase of feet above 50psi.
Including the 40psi data gives a SRC of +0.644, a strong (significant at 0.012 level) increase of feet above 40psi.
It's therefore clear that increasing pressure above 40psi results in an increase in feet, and that increasing pressure above 50psi does not.
*chosen because the data are non-linearly related.
"There's no tellin' where the money went"
-- Robert Palmer, "Simply Irresistible" (1988)
The Following User Says Thank You to LioNiNoiL For This Useful Post:
MetroMPG (04-12-2013)
Old 04-12-2013, 03:15 PM   #102 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Thanks for the analysis! I don't suppose you'd care to turn your skills to this related test ...
Also tested Oct 13, 2011... Bridgestone RE92 tires, multiple runs at pressures from 20-70 PSI. See this post: Experiment: coast down distances (rolling resistance) @ various tire pressures
Old 04-14-2013, 02:03 AM   #103 (permalink)
EcoModding Wannabee
LioNiNoiL's Avatar
more data analysis
psi feet
20 568
20 570
30 662
30 672
40 677
40 679
50 667
50 679
60 681
60 692
The same type of analysis of these earlier data is a bit more interesting than the previous analysis, because of the high SRC (+0.8944) between 60psi and 50psi, which has low significance (at 0.167 level) due to small sample size of only four pairs of data.
Including the 40psi data reduces the SRC to +0.667 with greater significance (at 0.074 level) because of more data.
Including the 30psi data increases the SRC to +0.761 significant at 0.014 level.
Including the 20psi data further increases the SRC to +0.877 highly significant at 0.0004 level.
In these data, it appears that increasing pressure to 60psi may result in an increase in feet (unlike the previous data) but the significance is low enough to diminish our confidence in this result. As is stated nearly always in such cases, we need more data.
The Following 2 Users Say Thank You to LioNiNoiL For This Useful Post:
MetroMPG (04-15-2013), mikeyjd (05-19-2013)
Old 05-19-2013, 08:28 AM   #104 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Thanks allot!
Originally Posted by LioNiNoiL View Post
psi feet
20 568
20 570
30 662
30 672
40 677
40 679
50 667
50 679
60 681
60 692
Thank you for optimizing our understanding of the existing data. I've been rocking 55-60 psi on my cars since I came across this thread and I've been happy with the balance between ride comfort and rolling resistance. Thanks to everyone who added to this thread.
Old 05-20-2013, 02:02 AM   #105 (permalink)
EcoModding Wannabee
LioNiNoiL's Avatar
I do a lot of hiking, and a fellow hiker has a Ford Excursion (huge SUV) who routinely has 65psi in his tyres (recommended for 45psi) having measured an increase in fuel economy by ½ mpg (more than that at 45psi) which for him is about 5%
Old 05-21-2013, 01:24 PM   #106 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
on a past road trip i stopped at a truck stop and cranked my PSI waay up. idk how much because i didnt have a gauge but it felt alot different. way more rough and easyer to stear without power steering. but when i got home the car was hopping. the tires bulged out and were ruined. so now im afraid of pumping them up real high. who knows. maybe i cranked them up like over 70 psi or something dangerous. they were real old tires too.
Old 05-21-2013, 02:05 PM   #107 (permalink)
justme1969's Avatar
yep
Ive said it many times tires dont survive over airing like back in 80s/90s
I did same the did it again just to be sure I was stupid! lol
dont take car tires past max inflation.
Old 08-12-2013, 01:15 PM   #108 (permalink)
Joggernot's Avatar
Long ago people were putting "airplane" tires that could be pumped to 300 psi on their cars for best mileage. Has anyone here done this? Has anyone checked to see if airplane tires would fit a 15 or 16 rim?
Joggernot
Old 08-12-2013, 02:13 PM   #109 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Aircraft tires aren't DOT approved, ergo not street-legal. You'd have to run them at ~200 psi, and fill them with water if you wanted to overinflate them.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
Pawtuckett (08-12-2013)
Old 08-12-2013, 05:08 PM   #110 (permalink)
OurInsight - '06 Honda Insight
It probably depends some on the tire brand and model. Insight owners have been very successful running 80 psi in the Bridgestone RE-92. There are lots of examples, with no recorded examples of damage, that I am aware of. I do suspect that damage would be more likely with old tires.
However, the gains in MPG at 60psi+ are very small if any. The Insight is a very difficult car on which to make such measurements, so it is a bit difficult to really know
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
