11-01-2012, 02:28 PM
#11 (permalink)
...beats walking...
Originally Posted by Diesel_Dave
Oddly enough, that was in New Jersey as well. Strange....
Oh the humanity!
...kudo's to you!--you caught my hidden inuendo!
11-01-2012, 03:38 PM
#12 (permalink)
Eco-ventor
That'll buff out.
11-01-2012, 04:28 PM
#13 (permalink)
DieselMiser
16 new cases of fisker fireball (do not get them wet)
11-01-2012, 04:40 PM
#14 (permalink)
DieselMiser
If this is what happens when you get them wet, I'd hate to see what happens when you feed them after midnight!!
The Following User Says Thank You to ConnClark For This Useful Post:
11-01-2012, 05:16 PM
#15 (permalink)
Smeghead
Oh the humanity!
[badpun]Oh the humidity![/badpun]
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
11-01-2012, 07:25 PM
#16 (permalink)
...beats walking...
...don't dew that!
11-02-2012, 08:08 AM
#17 (permalink)
Originally Posted by Daox
I highly doubt that lithium was the cause of this. Those cells are very well sealed I'm sure.
"Our source tells us they were “first submerged in a storm surge and then caught fire, exploded.”
It all fits with water and Lithium though.
It is extremely rare for a car that's just been submerged, i.e. soaking wet, to catch fire ...
Even a single laptop with a Li-ion battery in a burning car will have a spectacular effect , well beyond the gas tank going off.
Water only makes it worse, but the FD can't see wether there's such a laptop in a car .
FDs here are buying and carrying more D-powder fire extinguishers on their vehicles.
11-02-2012, 09:12 PM
#18 (permalink)
Location: sw Washington (state), a little north of Vancouver
As much as I would sincerely like to see them succeed, the awful truth is they are fodder for even car guys like Leno to get a laugh from!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
11-07-2012, 01:22 PM
#19 (permalink)
Here is the follow up:
Sandy Flood Fire Followup: Fisker Karma Battery Not At Fault
In a statement last night, the company said it has concluded--after "a thorough investigation witnessed by NHTSA representatives"--that the cause was residual salt damage inside a Vehicle Control Unit submerged in seawater for several hours.
Corrosion from the salt caused a short circuit in the unit, which led to a fire when the Karma's 12-Volt battery fed power into the circuit.
Heavy winds then spread that fire to other Karmas parked nearby. But, the factory said, there were no explosions, as had been incorrectly reported.
11-07-2012, 01:45 PM
#20 (permalink)
I actually like the design of the Fisker Karma and the RWD layout, but I've always considered its hybrid system too oppulent and quite dumb, since a smaller engine could perform the same job easily considering it's used just as a generator. Instead of the 2.0L turbocharged Ecotec the 1.4L one used in the Chevy Cruze and the Sonic would be enought, or even the N/A 8-valve one used in the Volt.
