Old 10-30-2012, 11:40 AM   #81 (permalink)
Originally Posted by adamj12b View Post
Hello Evimarn,
Yes, it would be easier to use 2 driver boards and 6 igbt's in 1 enclosure. I would do this, but I cannot fit it in my car. You would also need another capacitor ideally. Also, the harder part is to find and afford a current sensor that can measure all the way to 2000A. I have not looked into this yet, but I was thinking I could build a circuit that would measure 2 current sensors and create 1 output for the controller. It would also interrupt the gate signal to the drivers and use lockout to balance the current between the 2 controllers if it gets out of hand. Again, this is all in my head.
-Adam
I like your reasoning 2000A would be monstrous for me but not for your vette jealousy is overcoming me now hehe..
It would be really interesting to be beta tester what is involved ?
Please keep the info flowing you just have to keep it evolving Thanks again.
Mario
Old 10-31-2012, 09:36 AM   #82 (permalink)
ReVolt Enthusiast
I forgot about the current sensor until just now. I will have to finish this part of the controler. The logic board is compatable with many different current sensors, but in order to get 1000+ A of control, the normal HASS sensor is too small. -Adam
Hi Adam,
Could you tell me if Paul's Melexis HB current sensor PCB would be compatible with your controller ????
Current Sensor PCB
1000 amp test range
Thanks
-Mark
Old 11-01-2012, 12:09 PM   #83 (permalink)
PaulH
MPaulHolmes's Avatar
He's an artist! What artist is going to make 99% of his creation, and then stick someone elses crap inside it for the last little bit? ALSO, the current sensor needs to be calibrated for given bus bar dimensions. A LEM would definitely be less fuss.
kits and boards
Old 11-01-2012, 05:57 PM   #84 (permalink)
ReVolt Enthusiast
It seems to make more sense (no pun) to mount a small Hall sensor (Melexis - MLX91205HB) PCB flat on busbar.
The ring shaped sensor (HTFS-800p) with a connector and power conditioning circuit on a PCB sound like a lot more hardware than needed.
Yes, he would have to calibrate the height the hall sensor PCB on his busbar by shimming its height, but that still seams a lot easier.
-Mark
Old 11-03-2012, 07:39 AM   #85 (permalink)
EVVette - '71 Chevy Corvette Coupe
If you can find room to mount the surface mount sensor, you can use it, but if i remember correctly, it become impractical because it needs to be so far away from a bus bar wide enough for 2000A.
But in short, yes you can use it if you want to. There will be an option to enter the amps/volt into the controller so it knows what range it can measure.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
sawickm (11-03-2012)
Old 11-03-2012, 11:37 AM   #86 (permalink)
PaulH
For a 1 inch wide bus bar that is 1/4" thick, a 1/8" thick PCB (that acts both as the spacer and board you solder the chip to) gives a range of about -1200, to 1200amp. So, you would need another 1/8" spacer to get close to 2400amp. That's only for the Melexis HB, though. The LB needs probably 1.5" or something ridiculous.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
Old 12-04-2012, 02:11 PM   #87 (permalink)
Permanent Apprentice
Smile
I would like to purchase one of your initial protos for testing. If things go well, I would like to purchase two more for another project.
It will be used on a CR125 dirt bike conversion, powered by A123 cells.
I have experience with surface-mount soldering, so a box of parts would be fine with me.
Old 12-17-2012, 03:55 AM   #88 (permalink)
Hi Adam, how is it going any news still waiting impatiently for the good results/news.
Wishing every one here a Merry Christmas and a happy new year
Old 12-18-2012, 03:25 PM   #89 (permalink)
Work has slowed down to a crawl on the controller for the time being.
Ive had to dedicate all my time to a work project with a super tight deadline. I will have to get going on the controller soon though as there seems to be alot of interest lately.
Sorry Everyone.
-Adam
The Following 2 Users Say Thank You to adamj12b For This Useful Post:
evimarn (12-20-2012), sawickm (12-19-2012)
Old 12-20-2012, 01:00 AM   #90 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Adam,
at the risk of asking a stupid newbie question, is this a different controller to the one on your evvette site? I'm guessing that this is something new since the purposed specs in the thread are much better than the specs on the web site. Are you planning on selling this as a kit like the Cougar or a complete controller or both?
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
