03-14-2013, 05:41 PM
#51 (permalink)
T-100 Road Warrior
Dropped the extended diffuser about 1/2" after I got to Wichita. I'll see what it will do on the trip home. Not sure if the cold front affected my MPGs as much as it did but it was about 21.5mpg between Ardmore and Wichita...which is normally well above 26mpg during the summer runs.
Ended up cutting the side skirts...I'll see if this does anything fer the crosswinds or not.
I'll paint the beam flat black later on before I start driving back home.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
03-16-2013, 01:21 PM
#52 (permalink)
T-100 Road Warrior
Gitting packed up to head back home. Another cold front is coming in and it will probably be down in the low 30's by the time I git on the road. Brrrr...
Side skirt support rail painted black...
Up close...
03-17-2013, 08:48 PM
#53 (permalink)
T-100 Road Warrior
Hit 28.31mpg on the trip from Wichita to Ardmore with the cruise set to 65mph. It's usually around 23-25mpg.
Even maintained over 25.5mpg from Ardmore to Houston...with some speeds up to 100mph. I usually see under 25mpg at 65mph.
Nothing fell off or got ripped off at those speeds.
So I was thinking...the rear wheel skirts rubbed on the inside exposing the ribs. Wouldn't some of the air pressure being generated escape through those ribs and out the back side of the rear wheel skirts via the ribbed channels? Any data to suggest that using a channeled extractor setup would help?
03-18-2013, 04:46 AM
#54 (permalink)
One question, why don't you install side skirts between the wheels? I think that putting those further to the front would give you better air flow.
And moon discs on the front wheels
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
03-19-2013, 08:47 AM
#55 (permalink)
T-100 Road Warrior
I do have rear side skirts between the rear axle wheels if that's what you were referring to. They become the outer fence fer the rear diffuser.
Side skirts were full skirts but I had some problems with cross winds...so I just cut them down.
Moon disc covers sound nice but won't fit on my alloy rims.
Reason: Fergot to read the message...
03-19-2013, 10:04 AM
#56 (permalink)
Aero Wannabe
Unless you are willing to use the Bonneville racing style (which require drilling and tapping three small screw holes in your alloy rims) instead of the stainless snap-on style.
The latest VW XL1 only uses smooth rims on the front wheels, it has full rear wheel skirts. http://www.vwvortex.com/news/volkswa...wagen-xl1-037/
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
03-19-2013, 11:59 AM
#57 (permalink)
LOL, thats always a good thing!
I wouldnt worry about those ribs if i were you(unless your not gonna finish them, that is, i am a tad hungry )
The pure volume of air flowing in-out through smaller than straw size holes, 'efficiently' at that, is not worth the thought really. with the plastic already there as a guide, its already keeping the pressures seperated which is the main thing really
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
The Following User Says Thank You to RiderofBikes For This Useful Post:
06-13-2013, 01:27 PM
#58 (permalink)
T-100 Road Warrior
After running with full rear wheel skirts fer the past 6 months, I've removed the lower portion of the rear wheel skirts to git some numbers. I'm already missing the MPG numbers I've been gitting with them installed.
Made a run up and back to College Station in light traffic yesterday. MPGs going up with no load in the bed was an indicated 23.5mpg at 65mph. Coming back I got 24.2mpg at 65mph.
06-14-2013, 02:36 PM
#59 (permalink)
T-100 Road Warrior
Piccies...
06-14-2013, 09:57 PM
#60 (permalink)
An amazing project and well documented too.
Thank you for posting it.
