Old 03-14-2013, 06:41 PM   #51 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Dropped the extended diffuser about 1/2" after I got to Wichita. I'll see what it will do on the trip home. Not sure if the cold front affected my MPGs as much as it did but it was about 21.5mpg between Ardmore and Wichita...which is normally well above 26mpg during the summer runs.
Ended up cutting the side skirts...I'll see if this does anything fer the crosswinds or not.
I'll paint the beam flat black later on before I start driving back home.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (03-16-2013)
Old 03-16-2013, 02:21 PM   #52 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Gitting packed up to head back home. Another cold front is coming in and it will probably be down in the low 30's by the time I git on the road. Brrrr...
Side skirt support rail painted black...
Up close...
Old 03-17-2013, 09:48 PM   #53 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Hit 28.31mpg on the trip from Wichita to Ardmore with the cruise set to 65mph. It's usually around 23-25mpg.
Even maintained over 25.5mpg from Ardmore to Houston...with some speeds up to 100mph. I usually see under 25mpg at 65mph.
Nothing fell off or got ripped off at those speeds.
So I was thinking...the rear wheel skirts rubbed on the inside exposing the ribs. Wouldn't some of the air pressure being generated escape through those ribs and out the back side of the rear wheel skirts via the ribbed channels? Any data to suggest that using a channeled extractor setup would help?
aerohead (03-19-2013)
Old 03-18-2013, 05:46 AM   #54 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
One question, why don't you install side skirts between the wheels? I think that putting those further to the front would give you better air flow.
And moon discs on the front wheels
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 03-19-2013, 09:47 AM   #55 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I do have rear side skirts between the rear axle wheels if that's what you were referring to. They become the outer fence fer the rear diffuser.
Side skirts were full skirts but I had some problems with cross winds...so I just cut them down.
Moon disc covers sound nice but won't fit on my alloy rims.
Last edited by BamZipPow; 06-13-2013 at 02:27 PM.. Reason: Fergot to read the message...
Old 03-19-2013, 11:04 AM   #56 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Unless you are willing to use the Bonneville racing style (which require drilling and tapping three small screw holes in your alloy rims) instead of the stainless snap-on style.
The latest VW XL1 only uses smooth rims on the front wheels, it has full rear wheel skirts. http://www.vwvortex.com/news/volkswa...wagen-xl1-037/
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
BamZipPow (03-19-2013)
Old 03-19-2013, 12:59 PM   #57 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
LOL, thats always a good thing!
I wouldnt worry about those ribs if i were you(unless your not gonna finish them, that is, i am a tad hungry)
The pure volume of air flowing in-out through smaller than straw size holes, 'efficiently' at that, is not worth the thought really. with the plastic already there as a guide, its already keeping the pressures seperated which is the main thing really
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
The Following User Says Thank You to RiderofBikes For This Useful Post:
Old 06-13-2013, 02:27 PM   #58 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
After running with full rear wheel skirts fer the past 6 months, I've removed the lower portion of the rear wheel skirts to git some numbers. I'm already missing the MPG numbers I've been gitting with them installed.
Made a run up and back to College Station in light traffic yesterday. MPGs going up with no load in the bed was an indicated 23.5mpg at 65mph. Coming back I got 24.2mpg at 65mph.
aerohead (06-13-2013)
Old 06-14-2013, 03:36 PM   #59 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Piccies...
aerohead (06-15-2013)
Old 06-14-2013, 10:57 PM   #60 (permalink)
An amazing project and well documented too.
Thank you for posting it.
