10-20-2017, 06:19 PM
Civr - '95 Honda Civic Ri tinkerbell - '90 Honda integra xsi smokey - '00 honda civic gli 90 day: 43.36 mpg (US) takaka - '00 toyota echo base with ac and ps
post your idling L/hr consumption and....
post your idling L/hr consumption and if you have it readily available no load per hour fuel consumption
@2000, 3000, 4000 rpm
Please post: engine type, idling rpm (state lowered or stock), and any mods that might effect consumption: eg, no ps no ac belts etc
Thanks
10-20-2017, 06:25 PM
Ill start with mine:
civic ek1, d16y4, 1590cc, no ps, idle speed lowered to 720rpm.
.71 l/hr,
edit I re calibrated my mpguino and I believe it to be more accurate now. So new figure is .63l/hr at idle.
Also I tested at 2k rpm ...3...and 4k here are the results:
2k, 1.5l
3k, 2.6l
4k, 3.8l
I plotted this as a graph, please note my math skills are rusty very rusty but it appears it appears to be a linear graph or very close to it, at least up to 4k rpm I didn't test higher I should have but I didn't want to make anymore noise pollution.
I'd still like to get the idle speed down, I managed to get it to drop to very low rpm while I was water injecting, don't ask, the mpguino was reading .45l/hr! Although at that low rpm it wasn't smooth enough, but still I should be able to get close to that figure with a stable idle.
10-20-2017, 09:34 PM
0.0 because I don't idle.
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
10-20-2017, 11:50 PM
EcoModding flying lizard
I measured mine a while ago, before I removed the power steering.
2006 Accord V6, J30A5, 2997cc, stock(at the time), 700 rpm(stock, will have to verify actual rpm with scanguage)
1.32 l/hr
EDIT: Idle speed spec is actually 750 rpm, mine seems to hover right around 770 rpm. I have since brought out the the GPH gauge again after removing my power steering and have seen as low as .32 GPH(1.21 l/hr), but most of the time it sticks around .34 GPH(1.29 l/hr).
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
10-21-2017, 05:13 AM
Suzuki (Geo/Firefly) G10, 1.0l, 0.45L/hr. Hot/warm air intake keeps idle speed and consumption down.
The Following User Says Thank You to Stubby79 For This Useful Post:
10-21-2017, 05:33 AM
It's interesting to see others consumption at idle, I geussed my idle consumption initially and used it to roughly set my mpguino, ended up being very close.
Low Idle consumption is also good for key on coasting, I don't generally turn my motor off.
10-23-2017, 01:01 AM
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
3.5L V6, manual transmission, coolant-based warm air intake
warm idle is 1.1 L/hr at idle of 600 RPM.
The Following User Says Thank You to t vago For This Useful Post:
10-23-2017, 07:01 PM
1998 Acura Integra GS-R: 1.0L/hr
2015 Subaru WRX: 0.8L/hr
Both stock idle rpm with a warm engine.
10-24-2017, 09:00 PM
#9 (permalink)
I have to remember to test the no load consumption as rpm rises. I'll be going for a drive tonight so I'll remember to check and record data. I did my valve tappet clearances a few were on the tight side so hoping to see some improvement at idle if only a tiny one. I might have to block the tb by pass hole in order to further lower my idle speed. Potentially that could mean .2l per hour savings seems worth it, as I do a lot of engine on coasting.
Edit I checked and adjusted my valve clearances and advanced my timing unsure of exact degrees , this seemed to show no effect to my idling fe.
10-25-2017, 02:22 AM
#10 (permalink)
1.2 litre Honda Jazz. 0.68 litres/hour at 700 rpm.
