View Poll Results: What PSI are your tires at?
<35 PSI
0 |
0% |
35-40 PSI
22 |
32.84% |
41-45 PSI
19 |
28.36% |
46-50 PSI
11 |
16.42% |
>51 PSI
15 |
22.39% |
10-28-2019, 12:03 PM
#11 (permalink)
EcoModding flying lizard
51 front, 47 rear on my Bridgestone Ecopias, which have a max sidewall of 44 PSI.... I voted 46-50. I don’t plan on going higher.
Edge wear still slightly outpacing the center wear. I corner hard.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
The Following 2 Users Say Thank You to Daschicken For This Useful Post:
10-28-2019, 12:25 PM
#12 (permalink)
I run max sidewall on the Volt but it's been so long since I've seen the car I can't remember what that psi is. I'm pretty sure they're Michelin ES though
The other day I couldn't even recall what the rims looked like and had to Google "2018 Volt" to remember
The Following 2 Users Say Thank You to cowmeat For This Useful Post:
10-28-2019, 01:07 PM
#13 (permalink)
Chief - '06 Pontiac Grand Prix 90 day: 26.7 mpg (US) SF1 - '12 Ford Fiesta S 90 day: 30.95 mpg (US)
Did you really own a Volt or just a (bad?) dream?
The Following User Says Thank You to nemo For This Useful Post:
10-28-2019, 01:16 PM
#14 (permalink)
It could be two or three more weeks to get it back. I guess it'll be like getting a new car at that point!
The Following User Says Thank You to cowmeat For This Useful Post:
10-28-2019, 01:47 PM
#15 (permalink)
Rat Racer
If my tires are below 40, it feels like I'm driving through soup. But yeah, if I run over a dime, I know it.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 6 Users Say Thank You to Fat Charlie For This Useful Post:
10-29-2019, 03:26 AM
#16 (permalink)
eco....something or other
We used to run 45 psi in the rav4, but with the new "oversized" coopers the sweet spot seems to be around 36-38 psi. They have much stiffer sidewalls and are wider/taller, so they require less pressure to support the same weight. I could run them higher, but the ride would be horrible. It's already a stout ride. New hd coils in the rear and kyb shocks/struts all around. I love it. We have seen ~ 2mpg drop with the new tires, but they travel 6% more distance than the odometer reads, so it's all good. Currently averaging ~24 mpg since installing the new tires at 38 psi, compared to 26 mpg with the old ones at 45psi. The new tires are the very best we could find over the course of about 6 months of research. The rolling resistance on them seems to be about the same from 38-45 psi, so no need to make the ride harder with higher pressures. I have had tires that improved all the way to 60 psi, so these are definitely throwing me a curve ball with great performance at 38 psi. I run 80-100 psi in my truck when hauling, but that is only for carrying capacity/handling. The unloaded sweet spot is around 60/40.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following User Says Thank You to IsaacCarlson For This Useful Post:
10-29-2019, 08:51 AM
#17 (permalink)
My mom runs 50 PSI on her Prius. I ran 68 PSI in my Civic. Currently running 80 PSI in my Insight. Wouldn't recommend over 60 PSI unless you're an extremist.
From what I've read/experienced, tire wear seems to be best at sidewall max, and >70 PSI accelerates wear slightly on tires. Not all cars show a MPG improvement past 60 PSI, so unless yours does don't run them past 60 PSI.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following 2 Users Say Thank You to mpg_numbers_guy For This Useful Post:
10-29-2019, 09:43 AM
#18 (permalink)
This.
I tend to check them when my car is feeling wallowy and sluggish, and that’s typically just under 40. I pump them up to 48-50.
10-29-2019, 06:12 PM
#19 (permalink)
It seems that the consensus is that 40 PSI is a good minimum to start from. I am surprised to see an even distribution in the poll from 40 PSI.
I expect to see a really big mpg gain from these tires. I currently have 30 x 9.5 bf Goodrich tires at 35 PSI. I will be getting some A/S Michellin tires that are 235/75R15 and I will pump them up to 40 PSI. The nice thing about them is that they are more aerodynamic, 1/4 inch narrower and 29 inches tall
10-30-2019, 11:03 AM
#20 (permalink)
Originally Posted by Taylor95
Seems like 40 is a good starting point, and a lot of you guys go a lot higher with no issues. Thanks
Here is an old 2008 thread started by CapriRacer about Hyper-inflated tires. The thread ran till 2016 & has lots of info relevant to this thread:
https://ecomodder.com/forum/showthre...ires-2582.html
The Following User Says Thank You to litesong For This Useful Post:
