Old 12-03-2009, 11:15 AM   This thread is in the EcoModder Project Library | #1 (permalink)
Quest for a 400 mile tank
mjboks's Avatar
Adventure Truck - '07 Toyota Tacoma Double cab V6 TRD 4wd offroad
90 day: 19.26 mpg (US)
Commuter Bicycle - '94 Slingshot mountain bike
Aerocap for a Tacoma Pickup?
Okay, I've lurked around this forum a bit and found a handful of aerocap or aerolid including Bondo amazing aerolid, sepp's Nissan Aerocap (both versions), electricmans dakato aerocap along with akashic concept on his 1st gen tacoma and even the production version of aero canopies style they offer in Europe.
So I've reviewed many of the aero discussions about the optimal kamm back angle to avoid the dreaded seperation. Originally I was thinking of designing an aerocap with the magically 11-12 degree angle just for simplicity but then began reading the threads about the streamline template. Take a look at the image and let me know if I did that right and what do you think. When I overlay a 12 degree with a small transition curved area, it almost matches the template perfectly.
Name:	Tacoma Aerocap template.jpg
ID:	4914   Click image for larger version
Name:	Tacoma Aerocap template with cap design.jpg
ID:	4916   Click image for larger version
Name:	aerocap frame.JPG
ID:	4917   Click image for larger version
Name:	aerocap frame 2.JPG
Old 12-03-2009, 01:41 PM   #2 (permalink)
I also have been looking around for a cap to my '10 Nissan Frontier. Great start.
Old 12-03-2009, 03:54 PM   #3 (permalink)
The Leaf - '17 Nissan Leaf SL
Outback - '16 Subaru Outback
Vaquero - '20 Kawasaki Vulcan 1700 Vaquero ABS
Going to go with a clear section to see through?
How about side windows/cargo compartments?
Do you have any other use requirements, like it needs to be able to come apart and stowaway while carrying larger cargo that will not fit underneath?
Old 12-03-2009, 04:17 PM   #4 (permalink)
mjboks's Avatar
I thought about the see through issue but the location that is most important is right at the bend above the tailgate. I'm pretty good with just side mirrors but might like that rear viability of tailgaters. I might have to think about that some more.
Side cargo windows also would be nice. I found a dealer on ebay that makes custom picture windows for campers. I figure at least one from the cab to see back and then maybe a couple small side ones.
Hopefully it can be light enough so I can disconnect and lift it off with two people. I would say 95 percent of the time I can get away with a roof rack and storing gear underneath. I was thinking a hitch rack for bike transport would take the place of bikes in the bed. I think that'd be more aero.
I think the hardest part is lining up the aerocap with the back of the cab. The Tacoma has quite the contour on the sides and back. However, i want to keep this simple without any complex curves.
Old 12-05-2009, 03:27 PM   #5 (permalink)
old red taco - '02 toyota tacoma regular cab
90 day: 29.49 mpg (US)
i am glad i found this forum. i have a 2002 tacoma 2.4 4 cylinder 2wd 5 speed regular cab that i am collecting the wood to make a aero cap for shortly. i am currently getting just above 30 mpg. i have been figuring the back angle also and if i make the angle 11 degrees there will be only a 9' drop from the cab to the tail gate. the cab is about 21" so the verticle will be 12". but the caps i am seeing on this forum like the nissan and the ford f150 ones are 5" to nothing verticle at the tailgate. i am trying to figure how high i should make the back?
my truck is in pretty rough shape so i dont mind if it isnt the prettiest thing. i am planning on making it out of wood because of the trade i am in. i am figuring i can make it out of 2 sheets (39lbs) of plywood and 8 8' 2x2's (my guess 40lbs). so i am thinking it will weigh around 80lbs. i am not thinking of making it so i can see through it. if it bothers me i will install a back up camera mounted on the licence plate that can be bought at auto part stores. i am going to make the back panel above the tail gate removable so i can take a few screws out and i will have the height of the tail gate plus maybe about 10" to get in the bed. i also want to be able to remove the cap easily so i am going to try and mount it with some cap clamps from the inside.
Old 12-05-2009, 03:46 PM   #6 (permalink)
template
That IS the way to use the template.
I did a more comprehensive thread with "aerodynamic streamline template" which has a better "minimum" criteria for attached flow if you want to do a search for that.
Old 12-06-2009, 05:08 PM   #7 (permalink)
Old 12-06-2009, 05:09 PM   #8 (permalink)
ok how do i post pics?
Old 12-06-2009, 06:18 PM   #9 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Variety of options.
Simplest being imageshack.us
Old 12-06-2009, 09:24 PM   #10 (permalink)
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 36 08-06-2013 12:25 AM
2008 Dodge Dakota AeroCap electricman Aerodynamics 52 10-08-2011 11:47 AM
A Pickup Truck Project Big Dave EcoModding Central 47 09-12-2011 12:42 PM
Article: pickup mileage - manufacturers are ecomodding their trucks for better MPG MetroMPG EcoModding Central 14 10-08-2009 12:49 AM
Pickup tailgate up or down skyl4rk Aerodynamics 26 09-02-2008 05:49 PM
