Old 11-08-2011, 01:59 PM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I want AlMgB14 bearings and rings.
I was doing some reading and came across something interesting. There is a material that is ideal for bearings. It is AlMgB14 (sometimes called BAM) . It has a hardness that is very close to diamond and is slipperier than teflon.
Aluminium magnesium boride - Wikipedia, the free encyclopedia
it looks like a company called Newtech Ceramics has licensed the patent for the material.
Old 11-09-2011, 11:03 AM   #2 (permalink)
90 day: 19.36 mpg (US)
Have a look also at MICROBLUE RACING
Old 02-26-2012, 12:34 AM   #3 (permalink)
dead link?
Old 02-27-2012, 12:03 AM   #4 (permalink)
90 day: 40.51 mpg (US)
It's hard, but would it withstand the beating it would take as a rod bearing? Many materials are hard but prone to shattering, and thus are no good for this type of application.
Thanks for the link though, very interesting.
Old 03-23-2012, 03:48 PM   #5 (permalink)
For harder piston rings you could always go with tool steel rings.
They are pretty hard, I believe you need about a #400 finish on the cylinder bores to break them. Normal bore finish these days is done with #800 grit stones or finer.
