Old 12-27-2008, 06:03 AM   #1 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.5 mpg (US)
Consumption at idle
I had to try a Renault Twingo during one day [1] :
  • diesel 1.461L 65hp
  • manual 5sp
  • 3 doors
  • rated 45.2 (city) 61.9 (highway) 54.7 (combined)
  • CO2 113 g/km.
I plugged my SG2, which is incompatible with my 2 older Renault, and it was nearly fully compatible. It was missing TPS so the SG2 didn't had the open/closed loop information...
As I didn't know the cubic capacity when I plugged the SG2, I configured 1.6L, so the following figures are what I remember multiplied by 1.461/1.6.
I didn't had time this day so I have only been able to test the information I do not have in my scenic : the instantaneous consumption at speeds under 35km/h (21mph).
When the engine was started, the consumption at idle was at 1.65L/h (0.43gph). Ten seconds after it was down to 0.9L/h (0.24gph). After 1/4h of stop&go traffic, the consumption at idle stabilized at 0.73L/h (0.19gph).
Another thing I wanted to know is how much consumption the car has when you drive in 1st/2nd gear with the engine at idle (ie you doesn't touch any pedal). The results were :
gearL/100km/hmpgmph
1st18812.95
2nd91525.89
At these speeds, coasting in neutral would consume at 0.73L/h (0.19gph) :
km/hL/100mphmpg
89526
155948
The conclusion is that at low speeds it's certainly better to pulse 'n coast in neutral than keeping the engine in gear at idle rpm.
[1] the megane had a leak near the water pump, the thermostat melted in part and the temperature gauge was shifted down. As I didn't drive this car since months I though the low temperature shown by the gauge was because of near freezing temperatures and short commutes (20 miles). I worried when i saw the gauge going up & down... I had then not enough water in the cooling system. Happily it wasn't the water pump, but the water tank and a pipe.
Even without front grill (removed because this problem) and heating system at full load (in the hope to remove as much heat from under the hood) I achieved 43mpg, only 10% under my summer tanks
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 12-27-2008, 02:05 PM   #2 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.69 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 39.56 mpg (US)
Good find!
Must be nice. Mine is in the range of .69gph at idle. Which I think is the main reason most SUV's get junk for gas mileage.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 12-29-2008, 12:10 PM   #3 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
In the few minutes my MPGuino was working yesterday, even not-quite-calibrated, I noticed that with the car not moving at idle it would consume less gas in neutral than drive. (.43 gph in drive, .35 gph in neutral)
Old 01-08-2009, 09:25 PM   #4 (permalink)
LurkoModding Ecker
new beetle - '98 Beetle GLS
90 day: 32.98 mpg (US)
I have a 98 vw new beetle 2.0L gas 4cyl. it is around 0.28gph at idle which is 810rpm ish.
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong. -Buckminster Fuller
Old 01-09-2009, 04:23 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
groar -
Cool! I love the first-gen Twingo design. The cute name totally fits the car's looks. Wow, 65HP is only 5 more HP than my Dad's 1971 Karmann Ghia.
My 1.9L engine shows about 0.3 GPH at idle (under 1000 RPM).
CarloSW2
American Solar Energy Society
Old 01-09-2009, 05:08 PM   #6 (permalink)
holypaulie's Avatar
My Civic' 03 1.7L fully warmed shows 0.2 GPH at 750 RPM.
Old 01-14-2009, 12:57 AM   #7 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 18.11 mpg (US)
Heep - '011 Grand cherokee Larado x
90 day: 19.31 mpg (US)
Da bike - '06 Shadow Vlx deluxe
90 day: 53.94 mpg (US)
i get .35 in my 98 taco(2.7l) at 650-700 rpm (when warmed)
it would blow my mind to see .1gph
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 01-14-2009, 01:40 AM   #8 (permalink)
TacoModder
akashic's Avatar
rik's prerunner - '03 Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
My Tacoma gets the same. (As it should.) Though when I coast in neutral on the highway, I get .44 sometimes. Maybe all the time... I need to check more often. Does yours do that? Why would that happen?
Old 01-14-2009, 04:04 AM   #9 (permalink)
Pokémoderator
cfg83's Avatar
akashic -
Is the idle RPM also higher? My "idle RPM in neutral" will be higher at freeway speeds. I think it is something the ECU/PCM does.
CarloSW2
Old 01-14-2009, 05:17 AM   #10 (permalink)
Yea I get .45gph at coast even with my 5 speed.
a
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 08:18 AM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 01:41 PM
US Petroleum Consumption vs. Price Per Barrel Matt Herring Off-Topic Tech 10 10-15-2008 10:24 AM
