07-15-2009, 06:08 AM
Take me to your Earthling
Coroplast Kammback: joining or bending?
Now that I have a sheet of coroplast to fool around with, I'm wondering how to actually construct the Kammback. Should I make it out of three pieces (top + 2 sides), or should I make it out of one piece? In the first case, I'll have to find a way to join the pieces: screws, glue, ??? In the second case, I have no idea how to safely bend a 5mm thick piece of stiff coroplast. Should I heat it? On the outside, or inside? What happens when it cools? Will it try to straighten out again, will the bend be strong?
Any help, please?
Thanks,
--Adam
Piwoslaw's Peugeot 307sw modding thread
"You can't call yourself human if you think only of yourself."
An understanding of the laws of physics should be required on the driver's exam.
Originally Posted by blueflame
The more you drive, the less you think. Thats why I always take the bus.
07-15-2009, 12:51 PM
I haven't bent any coroplast with a heat gun but i'm guessing you'll only want to heat the inside of the bend. The skin of it is so thin that if the outside was heated it might stretch and deform and end up a mess. Also, the internal ribs will complicate matters by running along a different line than the bend you want. Murphys Law remember?? lol!
So i'm guessing you'll want to make a series of little bends close together so you end up with one big bend.
As i say, i havent done this but i have experience working with materials so it's an educated guess, subject to correction of course.
I have a few sheets of coroplast lying in my shed. I just need to find the time to use it! I also got some foam pvc sheet for my future kammback and wheel skirts: Foam PVC Sheet - 365 Plastics - Access Plastics Limited
I used some to blank off my fog light blank inserts and it bent well over the gas hob. Held its bend too. Plus it looks almost stock, apart from the screws.....
I figured it would look better than coroplast and would form better too. It was 20 euro for an 8'x4' sheet. Again, between working nights and looking after the kids, i don't get much ecomodding time.......
Unlike you, Adam. You're powering through this ecomodding at some rate!
Best of luck,
ollie
Having said all that i'd try bending the coroplast instead of joining. It's going to be harder to get the join to look respectable, what with brackets, screws and the edge itself. Plus, the bent coroplast will be more rigid and a little lighter without the brackets of joined coroplast.
07-15-2009, 02:05 PM
So maybe I'll try bending it around a pipe? Then it won't be a crease, but it'll be nice and rounded.
Thanks  I spent a lot of time getting ready, now I really want to get as much done as possible before our long trip to Romania in mid-August.
07-15-2009, 05:31 PM
Moderate your Moderation.
Got an oven that your complex shape will fit in?
Bend up a section of chicken wire, to use for a form (mold) then lay in a sheet of coroplast. Put it in the oven (find out what your Coroplast is made of, then find the melting temp for it) and heat it up. Let it cool WITHOUT opening the oven, and once it's back to room temperature, it will have a memory of the shape that you melted it into.
To join sheets to make them bigger, there are two ways. To join lengthwise (holes facing each other) you use plastic sticks in every couple holes and then slather some plastic epoxy between them, scrape off the excess when they're mated.
For the other direction, you take a couple old wire coat hangers, straighten them out, and bend them entirely in half, with no loop at the end. (So that the length of the hangers is parallel as good as you can get it.) Cut a notch into the corrugation of about 1/2" on either side of both sheets, slather the hanger with plastic epoxy and slide it in. Brush epoxy down the length of both sides of the seam and let it harden up.
(Plastic/Rubber cement also works.)
Originally Posted by tasdrouille
Because bean counters always win, that's why.
07-15-2009, 06:03 PM
YJ - '89 Wrangler Galant - '02 Galant LS V6
If you make it 3 pieces, use a piece of wood internally on the corner to attach the pieces together. The wood may need to be contoured to accomadate your shape.
If an angular bend is desires, you can remove both inner skin & ribs out of the desired area. I would probably heat the outer skin also. You may want to support the bend with some bent sheet metal as well.
Practice first.
Don
07-15-2009, 06:55 PM
Coasting Down the Peak
I bent coroplast using a propane torch and a straight edge. I clamped down the angle iron along the bend line and ran the propane torch flame along the bend line fairly quickly, with two passes. Then I immediately grabbed the plastic and bent it around the corner.
I used a steel(?) angle iron and an aluminum bar for straight edges. The bend is very strong.
You could also use separate parts and zip tie them together.
07-15-2009, 08:04 PM
Coroplast can be bent with the grain or up to about 30 deg either way by slitting the inner surface. Use a blunt-tip knife to save the other surfaces, and hold it at an angle so the cut edges slide over each other. For other forming, it is best to heat just the inside with a hair dryer or hot air gun. Sharp creases can be made by scoring with a blunt tool, and then running a bead of hot glue down the groove. That will first heat the polypropylene, and then help hold the shape. Oven heating can give full vacuum forming options, but you will probably make a large pile of scrap getting the process adjusted.
BTW, I have actually done lots of this stuff, not just guessed at it. Silicon seal works for bonding - I've never seen "plastic epoxy." Polypropylene is among the "waxy plastics" - hard to glue. COROPLAST HPV BODY CONSTRUCTION
07-15-2009, 09:25 PM
It's a 2-part epoxy that comes from most hardware stores. Isn't Coroplast made from PVA/PVC?
07-15-2009, 10:19 PM
#9 (permalink)
Well, "Coroplast Classic' is polypropylene, but there's no reason not to extrude almost any thermoplastic through the same sort of die. I've seen polycarbonate in thick panels for greenhouse use, for instance. Fresh from the factory, the regular signmaker's grade has a "Corona Discharge" treatment to help ink adhesion. I've gotten the very common WEST epoxy to stick, but not very well.
07-15-2009, 11:47 PM
#10 (permalink)
Pokémoderator
Piwoslaw -
I have *no* idea if this would work, but I was thinking of using a metal pipe and a heat gun. The heat gun would be aimed *into* the pipe to heat it up. If you were lucky, you could get it to have uniform heat. Hmmm, probably have to take turns heating the pipe from each end to maintain pseudo-uniformity.
But the other methods stated are proven,
CarloSW2
