04-02-2016, 06:39 PM
#121 (permalink)
What if its too efficient and vacuums out the cylinder causing more air and fuel to be pulled in?
This would be ideal for an N/A diesel in all conditions, because more air is always better for them.
For a gasoline engine this is only good if you want to burn lots of fuel and go fast.
Adjust the cam timing, problem solved.
The Metro has external EGR so it's not important to tune the overlap for efficiency.
04-03-2016, 10:12 AM
#122 (permalink)
Master Ecomadman
You should have these headers build a year ago... all these armchair theorists.
- Tony
09-12-2022, 08:10 PM
#123 (permalink)
What happened?
09-12-2022, 09:33 PM
#124 (permalink)
I'm doing it.
But not on a 1L metro.
It appears to be working for what I want them to do. Problem is I'm running out of 1 inch stainless steel pipe really fast.
09-14-2022, 10:38 AM
#125 (permalink)
I never made it, not sure it would have been worth it. It would have been a really fun project, but its a LOT of time to put into a project. That is not to mention the money aspect.
09-19-2022, 02:36 AM
#126 (permalink)
Ecomodding Apprentice
Make it and see
09-19-2022, 10:16 AM
#127 (permalink)
I'm making really long headers for small engines such as my lawn mower and stump grinder and it's definitely working.
It's not saving any fuel in the existing engine but on my stump grinder the straight pipe has given a nice little power boost making it so I don't replace the Honda gx390 with a predator 670cc V-twin.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
10-16-2022, 07:26 PM
#128 (permalink)
You might look into Anti Reversion ...er... doodats to ameliorate exhaust gas reversion on a std branch as a means of skipping the time and cost.
Also the Pressure Wave Termination which looks a lot like Anti Reversion after the optimal ...into 1 pipe length.
They look a lot like a large anti reversion doodat, but has the effect of 'fooling the branch in thinking it's exhausting into open air' and negating the unwanted effects of the mufflers.
https://ecomodder.com/forum/showthre...ion-40520.html
10-17-2022, 09:32 AM
#129 (permalink)
I put a 48 inch long exhaust pipe on my stump grinder 459cc engine. I'll see if it gives me a boost in power. I'm thinking the ideal length for me would be closer to 5 feet long but 4 foot is all I can manage.
10-17-2022, 12:01 PM
#130 (permalink)
Intakes can be plastic, right? That would be cheaper!
