Old 01-12-2016, 11:55 PM   #81 (permalink)
Tradition is to cut down a Model T torque tube, but that would be oversized, so: used motorcycle parts.
Old 01-13-2016, 11:16 AM   #82 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Originally Posted by Old Tele man View Post
And, (maybe?) you aren't restricted to ROUND header pipes (?!?!?):
...which remind me of waveguides used in microwave radars!
Besides being far more difficult to find as mandrel-bent pieces and harder to fabricate, flow would be worse due to interference drag at the 90° intersection between the walls. The only reason square-ish runners are used in intakes or exhausts is for transitions dictated by other components (e.g. bolts, pushrods, adjacent runners).
Old 01-13-2016, 12:52 PM   #83 (permalink)
http://slideplayer.com/slide/4767166/
3D Reconstruction 2
Round mandrel bent steel is still an approximation. To see really optimized flow look to your own arteries.
Old 01-13-2016, 07:11 PM   #84 (permalink)
Yes. In general if not specifically. Also note the oversizing of the 'collector'. I didn't see a version that showed a three-way split.
The asymmetrical flaring of the end cuts would probably improve scavenging.
Old 01-13-2016, 10:51 PM   #85 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Not directly related, But of interest.
The Following 2 Users Say Thank You to ConnClark For This Useful Post:
Joggernot (01-14-2016), pgfpro (01-17-2016)
Old 01-15-2016, 06:03 PM   #86 (permalink)
You could use longer primaries if you did this:
Just A Car Guy : twisted and tangled
Old 01-16-2016, 08:29 PM   #87 (permalink)
That requires skill!
Old 01-17-2016, 12:26 PM   #88 (permalink)
silverado30mpg - '90 Chevrolet Silverado 2WD w/ 3.08 gear
90 day: 18.91 mpg (US)
BuzzBuzz - '91 Suzuki Swift GT
90 day: 159.12 mpg (US)
My initial thought with the pipes going straight back is this could be used to accelerate the air flow past the tail of the underbody like a blown diffuser...
Old 01-17-2016, 12:48 PM   #89 (permalink)
Exhaust is corrosive, anything you do like that would need to be all stainless steel.
Old 01-18-2016, 12:41 PM   #90 (permalink)
I'd imagine we want to keep the angle at 15 degrees or less.
With converging and diverging nozzles I believe 7 degrees is ideal.
There are companies that sell 7 degree reducers for intake and exhaust piping, they are kind of expensive.
I picked up a 304 stainless steel 3 to 4 inch reducer pipe used in a water pumping system to be part of my diesel suburbans new exhaust. It has about a 12 degree slope. Not perfect but since it was free I cant argue. (had a welding defect and could not be used in the high pressure RO system it was intended for)
