Old 05-22-2012, 05:28 PM   #41 (permalink)
Doug - '03 Chrysler PT Cruiser Base
90 day: 31.16 mpg (US)
DR 350 - '92 Suzuki DR 350 S
90 day: 61.09 mpg (US)
Sid the Sloth - '82 Honda Civic CVCC Wagon
Last 3: 35.93 mpg (US)
Rocky - '92 Daihatsu Rocky
Last 3: 24.97 mpg (US)
Mick - '97 Jeep Cherokee XJ UpCountry
90 day: 19.4 mpg (US)
Does it bog just revving it or only under load? Can you post a vid of it running?
Old 05-22-2012, 05:41 PM   #42 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
It bogs only under load, 10-20 % throttle it has lots of power over that is when it bogs.
I just finished pulling the carpet and rear seats, so I am going to clean up my tools, and do a couple more things than I will see about getting a vid up.
Old 05-22-2012, 07:54 PM   #43 (permalink)
Sports Cars
Pickups
I GOT IT!!!!!!!!!!!! It was the Egr. I pulled the vac line plugged it with a screw and took the car for a test drive. It's at 99% now, tomorrow I will change the plugs and wires, I checked the number 1 plug today and it looks like spark is jumping the insulator.
I also removed the rest of the carpet, the rear seats, rear seat belts, rear speakers, wired a power plug for my Gps, cell charger, fixed the Egr, and put new wire spacers in.
Old 05-23-2012, 01:44 PM   #44 (permalink)
Nice, I was going to suggest vac leak or egr...glad you found it! I love restoring older cars to almost factory condition. There's a lot of good old cars out there just rotting away in barns/garages/fields cause one little thing was wrong with them.
Old 05-23-2012, 03:11 PM   #45 (permalink)
Sports Cars
Pickups
The pile of stuff I took out of the car yesterday.
The old sparkplugs... In order from 4-1 Number 2 is rich for some reason.
Old 05-23-2012, 05:55 PM   #46 (permalink)
Sports Cars
Pickups
I built an airdam today to replace the lawn edging. I bought the poly @my local glass shop
Total cost $30
Parts
1 4"x48"x3/16" clear polycarbonate
2 4"x24"x1/8" clear polycarbonate
3 A handful of 3/8" #8 sheetmeatal screws
4 Polycarbonate Paint
1st marked and drilled holes, large enough to fit the threads through.
2nd Positioned the corner where I wanted it and marked and drilled those holes.
3rd Paint. If you paint the back you will have a glossy finish, and be protected from rock chips, if you paint the outside the finish will be dull, paint damage possible.
4th Reinstall, make sure everything lines up. A coat of paint dries in 15 min or so, multiple thin coats are best.
Old 05-23-2012, 06:14 PM   #47 (permalink)
Sports Cars
Pickups
Pics of my air dam.
I should have put more coats of paint on the big center piece.
Old 05-23-2012, 07:58 PM   #48 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
Nice.
I think u should paint the grill block black or dark grey.
I think that car is awesome.
Old 05-23-2012, 08:44 PM   #49 (permalink)
Sports Cars
Pickups
Thanks Taco. This isnt my favorite grill block , it looks cheap. I like the look of duct tape better. The white pulls your eye to the paint chips and rust on the hood haha.
Old 05-24-2012, 01:39 AM   #50 (permalink)
Sports Cars
Pickups
Last tank, 25.5 mpg, not fantastic but acceptable.
Leaving for Boise tomorow, 4 passes, 60 mph max speed, hopefully no wind. I get totest my new airdam tomorow. The bummer is packed for 4 days= extra weight., our luggage is packed were the back seat used to be.
