Old 08-25-2008, 05:28 PM   #1 (permalink)
Meph's Avatar
240Z - '73 240Z 240Z
90 day: 34.41 mpg (US)
Driving with a vacuum gauge
Ive been looking into pick up a boost gauge to try and max out my MPG. Ive read about the basics behind using one for economy but I'm still a little lost.
Keep in mind the car is OBD 0 so scanguage isn't an option as far as i know.
so, once this thing is installed, how do I interpret it to get the best economy?
Old 08-25-2008, 05:52 PM   #2 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
Try to keep the engine vacuum as high as possible.
Old 08-25-2008, 05:57 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Here are what normal vacuum readings should be on a properly working gauge and a properly running engine.............
IDLE - 18-22
DECEL - 22-30
ECONOMY - 10-18
POWER - 0-10
The goal to saving fuel is to monitor it while at cruising speed. Keeping a constant reading like 10-12 will net the best results. Never accel hard so it drops below 5 because that is just a waste of fuel. Watching it at idle will tell you if the engine is running properly. The gauge should really not fluctuate at idle if it's running right.
I do use mine during accel. I keep it at 10 or higher and shift whenever I feel it will not draw more then 10 for the next gear. It's usually right before the shift light comes on, but if I am going up a hill, I will stay in the gear that gives me around 10 even if this involves higher RPM's
Old 08-25-2008, 06:55 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
As long as you have electronic fuel injection you could use the MPGuino.
Old 08-25-2008, 07:13 PM   #5 (permalink)
Meph's Avatar
can you use the gauge to find your cars peak MPG speed somehow?
Old 08-25-2008, 09:34 PM   #6 (permalink)
Hi-Tech Redneck
The gauge is mostly used for maintaining throttle position since it is very load sensitive.
Old 08-25-2008, 10:37 PM   #7 (permalink)
Meph's Avatar
so for best results, it would be a good idea to:
-get the most vacuum possible while cursing at a speed (something around 10-14)
-Try to maintain a vacuum close to that number when accelerating. ( i thought the general rule was high throttle and low rpm, or will that condition be produced?
Without a scangauge or MPGuino is it possible to determine what Speed/Vacuum is most efficiency?
Thanks for the help
Old 08-26-2008, 01:08 PM   #8 (permalink)
ScabbySentra - '93 Sentra SE
90 day: 44.37 mpg (US)
Thanks for the help
The fuel usage is directly proportional to the throttle opening, the RPM, and inversely proportional to the vacuum. Try to maximize vacuum while minimizing throttle opening and RPM's, and you'll be on the right track. The efficiency of the engine won't be reflected in these factors, if I understand right, so you won't be able to see peak efficiency with enough accuracy to really be helpful.
Old 08-26-2008, 03:16 PM   #9 (permalink)
Meph's Avatar
got the gauge installed today, I'll see how it works out tonight.
Thanks guys
Old 08-26-2008, 10:27 PM   #10 (permalink)
Sure it's fuel-injected?
He says it's OBD-0 so maybe he means it's a carbed car.
Ray Mac
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 76 07-29-2010 09:52 PM
Any advice for driving by vacuum guage? video Chris D. Instrumentation 33 02-22-2009 12:54 AM
Vacuum gauge DifferentPointofView Instrumentation 18 10-24-2008 04:31 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-15-2008 12:04 AM
