Old 11-25-2007, 10:05 PM   #1 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Engine efficiency improvement through higher temp thermostat?
The hotter the engine the more effecient. I'm currently running water temps of 200-207. If I bumped that up to 215-220 and ran a high quaility coolant. What kind of bump in FE do you think? At what temp would the head gasket become a concern.
"Judge a person by their questions rather than their answers."
Old 11-26-2007, 04:36 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I can't answer the thermal stress question, but do have another one: will your engine let you run at higher temps? What's your electric fan's trigger temp?
Temp is a tricky issue because another effect of more heat is less timing advance (engine may be more likely to ping the hotter it gets).
Old 11-26-2007, 05:56 PM   #3 (permalink)
ECO-Evolution
Lazarus's Avatar
C-3 - '08 XF50X
I would have to tweak the fan. Right now it comes on at 213. From what I can tell from the scan gauge the timing is affect greatly by IAT but not so much by WT. I'm also thinking that this coolant, although pricey, might actually help in that regard and running it at 220- 225 would be the equivalent to the current 210.
Old 11-26-2007, 07:46 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Aren't you concerned about the increase in nox emissions from running hot?
Old 11-27-2007, 07:16 PM   #5 (permalink)
ECO-Evolution
Lazarus's Avatar
C-3 - '08 XF50X
No I don't think that there will be an increase in NOx. Increasing the engine operational temp is not like going into lean burn. The A/F would still be stoich(?) right ?
Old 11-27-2007, 07:18 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Well, the engine should lean out the mixture while running hot. Also, I have generally seen it stated that NOx increases on hot engines.
Old 01-19-2008, 07:24 PM   #7 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Instead of running your engine hotter, see if you could rig a cold-air intake for your induction system. An extension from the filter housing that runs right up to an opening (gasp!) in the grille or perhaps in a wheelwell, would permit a cooler, denser air charge. It's almost like having a very light-pressure, lagless supercharger.
If you do decide to run a hotter thermostat and hotter fan setting, consider running an auxiliary oil cooler. Again, you could put that someplace that doesn't require it be out in the wind, like flush with the belly pan (behind a screen for protection from stones) or tucked in a safe place inside a wheelwell.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 01-19-2008, 08:33 PM   #8 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
I use a 203 degree thermostat, and Evans propylene/ethylene glycol coolant.
I gained 0.5 MPG by doing this. One of the few engine mods I've seen work.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 01-19-2008, 09:23 PM   #9 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Is that like a bicycle almost being like an Interceptor?
slotech (11-10-2009)
Old 01-20-2008, 12:15 AM   #10 (permalink)
ECO-Evolution
Lazarus's Avatar
C-3 - '08 XF50X
Actually I have done this with no affect on FE. Tested it up to 60 mph with no increase.
DIY - Thermostat Install SVOboy DIY / How-to 2 11-18-2008 03:32 PM
Heat engine block for efficiency? bennelson EcoModding Central 43 08-12-2008 09:45 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
