Old 06-30-2011, 02:30 PM   #1 (permalink)
katiep's Avatar
Red - '04 Aveo
90 day: 35 mpg (US)
EOC and non flat-towable car - any way to fix?
I want to know if there is any way to modify a car so that one that can't EOC would then be able to EOC without resulting in damage.
Old 06-30-2011, 02:38 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
It will take some research and a fair amount of work, but it can probably be done. You need to tap into whatever passage is used to oil the transmission components and add an electric oil pump to keep oil going to the transmission bits. You'll also have to come up with some way of turning this pump on and off.
The Following User Says Thank You to Daox For This Useful Post:
katiep (07-01-2011)
Old 06-30-2011, 02:53 PM   #3 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
With an electric pump, use a relay tied to the ignition or accessory power.
The Following User Says Thank You to TheEnemy For This Useful Post:
katiep (07-01-2011)
Old 06-30-2011, 03:02 PM   #4 (permalink)
one of thOOOse people
twitchy - '98 civic dx + sir + ls
90 day: 33.35 mpg (US)
Swap in a manual transmission. I believe most manuals are flat towable. At least enough to EOC.
The Following User Says Thank You to hamsterpower For This Useful Post:
katiep (07-01-2011)
Old 06-30-2011, 03:18 PM   #5 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Look for a RV dealer and call them tell them you want to flat tow a car behind an RV but the manual says that the vehicle is non flat-towable and do they have any external transmission pumps to correct this. That way you can find a local place that might have on and you could find out the price.
I move at the speed of awesome.
The Following User Says Thank You to Phantom For This Useful Post:
katiep (07-01-2011)
Old 06-30-2011, 05:55 PM   #6 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
I myself have done this, most RV Dealers will tell you to start the engine and place the Trans in Neutral in order to tow them.
The Following User Says Thank You to Joenavy85 For This Useful Post:
katiep (07-01-2011)
Old 07-01-2011, 12:00 AM   #7 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Protege5
90 day: 32.52 mpg (US)
what the others have said is about spot on.
the only other way to accomplish this would be a pump that turns with the wheels or driveshaft, but honestly that route might take a lot more work than a simply electric pump
~Mike
The Following User Says Thank You to d0sitmatr For This Useful Post:
katiep (07-01-2011)
Old 07-01-2011, 09:35 AM   #8 (permalink)
katiep's Avatar
Red - '04 Aveo
90 day: 35 mpg (US)
but not all?
"Most," but what did any others say? Basically the same suggestions? I might try a phone call or two to see if the RV dealers near me will be helpful. Hmm!
Old 07-01-2011, 09:49 AM   #9 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
I wouldn't EOC an automatic. Best to just neutral coast.
There are some that do successfully EOC with an automatic though. Not worth the risk or the hassle in my book.
2006 3500 Dodge QC/FB 5.9 handshaker
