06-05-2008, 04:44 PM
#21 (permalink)
ECO-Evolution
I think it kind of interesting that the smaller tire there was a pretty big jump until about 45 psi while the bigger tire was at a lower pressure of around 35. I would of thought that it would of been the opposite.
"Judge a person by their questions rather than their answers."
06-05-2008, 08:10 PM
#22 (permalink)
Originally Posted by dcb
re: variance. Did you mark your starting position in two dimensions?
No, I didn't. It's possible (likely) I was off laterally a little from run to run.
On the starting hill, I moved into position each time by sighting down a wall beside me that was perpendicular to the roadway, and creeping the car until my line of sight was straight down the wall. Then I stopped completely and released the brakes when the coast was clear.
Is there any reason to think that the brakes might not release evenly?
I wondered that too. I suppose it's possible.
01-20-2009, 09:23 PM
#23 (permalink)
To put this into perspective for a metrompg.com post I'm working on (not up yet), here's the Firefly coasting results shown to scale:
click to zoom...
01-20-2009, 11:00 PM
#24 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Regarding Lazarus' post on the larger tire having less difference in distance per PSI level:
The larger tire has significantly stiffer sidewall area, which reduces rolling resistance. Obviously it's 40-60mm wider (manufacturer's measurements vary), but that may not win-over the loss of friction and warpage associated with tall/thin sidewalls.
01-20-2009, 11:24 PM
#25 (permalink)
Camryaro - '92 Toyota Camry LE V6 90 day: 31.12 mpg (US) Red - '00 Honda Insight Prius - '05 Toyota Prius 3 - '18 Tesla Model 3 90 day: 152.47 mpg (US)
Originally Posted by MetroMPG
What I find so interesting is the level of variation between runs, even with such a simple test.
Maybe the lube cooled off. There is a huge difference in coasting speeds in my truck w/ a 50F difference, and given the operating range of greases/oils I imagine there could be a pretty big increase in drag relative to the change in Crr at those speeds as stuff cools.
05-12-2009, 07:01 AM
#26 (permalink)
MetroMPG:
What pressure are you using for every day ?
Thank you.
05-12-2009, 02:23 PM
#27 (permalink)
50 ish.
05-12-2009, 03:17 PM
#28 (permalink)
distance
Darin,my thoughts are that if the car had been tested from some initial velocity,to a lower velocity,or stop,that you might have seen a greater spread in the data.Evidently,the starting force,which must be overcome just to get a car moving is remarkably high,compared to once its rolling.This is a reason for the traffic light synchronization,as "stops" eat a lot of energy.---------------- I think this effect is cutting into your numbers,although I realize the added complexity and variability of the coast-down.My suspicion is that your RR performance is actually much better than the numbers reflect.Your test does reflect a measurable effect so I say it's useful to all,kudos to you and !muchas gracias!,Phil.
05-12-2009, 10:08 PM
#29 (permalink)
I agree, a "normal" coastdown from some moving speed would have made for a better test, Phil. No argument there.
08-02-2010, 03:17 PM
#30 (permalink)
Polymorphic Modder
Thanks for posting and running the test. Has anyone had a blowout from running pressures exceeding the tirewall max?
