Old 11-16-2010, 11:12 AM   #1 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
Experiment: The cost of Headlights
I know it's been said to keep the headlights off for MPG, and I'm sure it does make a difference. But I had never seen the difference quantified. I had a few extra minutes today so I did a test with my car, using the scangauge to get numbers.
Temperature was in the mid 70's (I'm in florida, clear day) at 2:15 PM on 11-15-10. (in case anyone wants to look up the weather) I did 2 runs in each direction on a long flat stretch. Roughly 1.1 mile apart from each marker. Cruise set at 55 mph and given plenty of time to stabilize the speed before markers and then resumed for each run. You know, standard testing here.
Test 1: No headlights.
A: 35.0
B: 36.2
A: 35.7
B: 35.1
Average: 35.5, Testing Range is 1.2
Test 2: Headlights on. Low Beams only
A: 34.8
B: 34.7
A: 34.4
B: 34.6
Average: 34.6, Testing Range 0.4
Test 3: Headlights Back off
A: 36.4
B: 35.5
A: 35.2
B: 35.1
Average: 35.6, Testing Range 1.3
So without Headlights, I'm seeing 35.55 MPG Average.
With the headlights I'm seeing 34.6 MPG Average.
So 0.95 MPG, or around 2.5%. I'm sure with the high beams on the difference would be larger.
Another quantified reason why winter mileage seems like an uphill battle.
Daily Driver
Winter Beast
The Following 11 Users Say Thank You to brucey For This Useful Post:
California98Civic (05-22-2011), cfg83 (11-16-2010), ConnClark (11-16-2010), endurance (11-29-2010), JacobAziza (12-01-2010), NeilBlanchard (11-16-2010), Piwoslaw (11-16-2010), SwamiSalami (05-22-2011), turin (12-01-2010), Weather Spotter (11-16-2010), Zerohour (11-29-2010)
Old 11-16-2010, 12:27 PM   #2 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Thanks for taking the time and effort to test this, but the variation in the results is at least equal or even bigger than the observed difference between the 2 conditions.
These small improvements simply can not be tested and quantified on the open road with a few drives up and down.
Lifetime fuel consumption :
Old 11-16-2010, 12:39 PM   #3 (permalink)
what is the theory behind reducing electrical load to increase mileage? it's not like your alternator is on a clutch and only kicks in when there is more electrical load than your battery can supply. it runs at the same speed all the time (or at least the same speed in proportion to engine rpm).
Old 11-16-2010, 12:53 PM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Increasing the amount of electric power you use increase the load that the alternator puts on the engine.
Old 11-16-2010, 12:54 PM   #5 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
The battery only supplies power when the engine isn't running. While the engine is running, the battery is actually a load, and it is the alternator that powers everything. If you increase the electrical load, then the alternator has to work harder, and so it saps more torque from the engine.
The alternator doesn't put out "extra" power either -- if only all the hydrogen generator proponents knew this...
Old 11-16-2010, 04:26 PM   #6 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
The higher your mileage, the greater the mpg hit from the headlights or any other electrical load. On the aerocivic, using the headlights knocks my mileage down about 2-3 mpg, but the mileage hit is almost unnoticable against the background noise on my F150.
Old 11-16-2010, 05:06 PM   #7 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
From the theoretical side, with some VERY quick-and-dirty math:
My car uses
110w = 2x 55w headlight
75w = 3x 25w taillight, including high-mounted
185w extra load
Alternator: 60% efficient (Alternator - Wikipedia, the free encyclopedia)
Lights on = 308w extra load on the engine
308w/ 745 watts in hp = 0.41 hp extra load
Using the calculator, my car needs ~10hp to roll at 55 mph.
0.41 hp is a 4.1% loss of efficiency at that speed.
11% loss at 35 mph
2% loss at 70 mph
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
The Following 3 Users Say Thank You to PaleMelanesian For This Useful Post:
JacobAziza (12-01-2010), Lokalazeros (11-16-2010), NeilBlanchard (11-16-2010)
Old 11-16-2010, 06:15 PM   #8 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Surprisingly, high beams are typically 60W, versus 55W for low beams. It's not so much that there's more light, it's mostly that it's cast further down the road. Also into oncoming drivers' eyes.
Good work, Brucey (and Pale).
Btw, what speed did you set the cruise to?
Old 11-16-2010, 07:34 PM   #9 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
Thanks for the data!
I added it to the electrical loads page in our wiki:
Electrical Loads - EcoModder
Old 11-16-2010, 07:46 PM   #10 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I would tend to give more weight to the derived value than the road tested one because as noted road testing is so loaded with variables. The general agreement with the results is good though!
DIY LED Headlights SVOboy EcoModder Blog Discussion 44 09-06-2011 07:48 PM
Using Magnets to increase milage hondo434 Off-Topic Tech 71 08-13-2010 12:48 AM
Engine-off experiment mattW Hypermiling / EcoDriver's Ed 8 02-18-2008 12:57 AM
Cost of Gas VS Cost of Food Peakster The Lounge 13 02-08-2008 08:15 PM
